Is this command in bold the equivalent to 'Enhanced interference management' in Asus stock or Merlin builds?Well now that you have 64K cfe you can turn on UPNP and that will help especially if you have windows 8 and all its media programs... Also check under wireless settings and make sure you dont have afterburner on... oh and 1 last thing... telnet into the router and do:
wl -i eth1 interference 2
This turns on interference mitigation mode and makes it stick, this helps in high noise 2.4ghz enviorments.... I get 300mb on 2.4ghz band with my n66U and 450mbs on the 5ghz band with my macbook pro 2012.
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=720564&sid=695f502795f09a7ebeb4e7af4be1b878#720564
- lfbb
