Intermittent VLAN access
psy-q
I'm having very intermittent network access over a switch on my network.
RT-N66U Tomato -> Cisco SG300-10 -> Netgear GS108E
I've got VLAN 2,3 & 5 trunked from the SG300 to the GS108E. It works when I swap ports on the GS108E for a minute or so, then the connection fails and the only client (my laptop) starts spamming the gateway with ARP requests(unsuccessfully). Nothing seems to be getting through and I can't ping anything in or out of my LAN.
The weird thing is it DOES work fine for a few minutes/seconds. Also, if I disconnect the GS108E and plug the laptop directly into the switch on the same port it works. I can switch the VLAN on the NIC and get full access to every subnet.
I've messed with STP, smartport(disabling), swapped ports on the SG300 and used a couple different NICs for testing(built-in and USB).
Stumped... help! :confused:
