iptables entries not run from openvpn-event on reboot
GoldenEye
I'm running version 384.17 of Asuswrt-Merlin on an RT-AC66U_B1, I have an openvpn-event script in /jffs/scripts that uses a template that calls a vpnserver1-up and vpnserver1-down script. These up and down scripts contain custom rules I add to the iptables, the first and most important being the following to remove the entry "OVPN -d 192.168.18.0/24 -i tun21 -j ACCEPT" for global access to the network on vpnserver1 using the commnd "iptables -D OVPN -d $subnet.0/24 -i $dev -j ACCEPT"
I can see through the logging that the scripts get run on a router reboot and when restarting the vpn server through the UI, the problem is that the iptables changes seem only to be applied when I restart the vpn server manually in the UI, if I reboot the router the changes don't get applied despite seeing my log entry that the script was run.
Wondering if anyone might have some ideas on a solution or way to further debug this?
Thanks.
Thanks.
you need the rules also for nat-start or firewall-start to properly ensure rules don't get skipped between reboots simply add your vpnserver1-up script to either nat-start or firewall-start should resolve this issue.
I gave a try using both of these, but the same behavior seems to persist regardless of which script I run from and according to the log the openvpn-event is being run before the nat-start or firewall start which seems strange.
I was however able to glean another point of info, switching back to using openvpn-event which used to work, after a reboot I quickly connected via Putty to run iptables -S, doing this several times in succession over about a minute I was able to see that the rules actually did get applied, but them for some reason were wiped again shortly after with everything being put back to default.
Additionally I do have the VPN server being connected to by a client after reboot and am also connecting as a client to another server and can see some of this as the first logged events on reboot. I'm not sure if there could be a bug in the mix here causing scripts to trigger early, as I was quite sure this all worked at least some versions back.
