Kr00k vulnerability 2020
Some already did. Examples for some popular ASUS models:
ASUS RT-AC66U-B1 Firmware version 3.0.0.4.385.20253
- Fixed CVE-2019-15126 (Kr00k) vulnerability.
ASUS RT-AC68U Firmware version 3.0.0.4.385.20253
ASUS RT-AC86U Firmware version 3.0.0.4.384.81352
ASUS RT-AX88U Firmware version 3.0.0.4.384.7997
What about the rest ?
They need to get fined if they don’t patch it in an acceptable timeframe, I think they will blame it on the pandemic.
* Asus patched RT-AC88U too
They need to get fined...
If you read carefully what Kr00k actually is, you'll find it's a bug allowing decryption of limited amount of packages in a very specific moment. It's not like a door to your network or anything close. The eventual attacker should be in range of your WiFi and still doesn't have full access to transmitted data.
This security hole has a risk score of 3.1 out of 10 with NVD. There is absolutely zero reason to panic about this.
Beside, this is a client issue. Routers are not at risk if they are running as routers/access points.
Version 3.0.0.4.384.86812020/03/1960.2 MBytes
ASUS RT-AX92U Firmware version 3.0.0.4.384.8681
Can router manufacturers step in and fix it ?
I suggest you go ask them all and come back and let us know what they say.
OE
C TP-Link Archer High Vulnerability General Network Security 4
