LAN Switch enable bonding and disable STP kills LAN
stephen_d_hill
I have enabled LAN->Switch Control ->LAN bonding on my RT-AX86U, and connected both cables to an my LANs Eth switch which has enabled Active LACP on those ports. This seems to work okay (checked logs of switch and router). But, if I disable STP (LAN->Switch Control ->Spanning-Tree Protocol) I lose the LAN ... the question is why?
Make sure your switch ports are configured for 802.3ad and not one of the other aggregation modes. It sounds like link aggregation on the switch isn't working at all and therefore STP is preventing a loop condition.
I am using an HP1810-8G Eth switch ... it only supports LACP (802.3ad). I have set the trunk on the switch to 'LACP Active'.
The trunk connected to the RT-AX86U is TRK2 (WiFi) and seems to be working, given there are packets seen on both interfaces/ports from the Eth switch GUI:
TrunkNameTypeAdmin StatusLink StatusStatic ModeTrunk MembersActive Ports
TRK1ServerDynamicEnableUpDisable7,87,8
TRK2WiFiDynamicEnableUpDisable1,21,2
Port Statistics:
InterfaceReceived Packets w/o ErrorReceived Packets with ErrorBroadcast Received PacketsTransmitted Packets w/o ErrorsTransmitted Packets with ErrorsCollisionsTransmitted Pause FramesReceived Pause Frames
111768547202026502861284660000
2275559084208143823072150350000
Trunk Statistics:
TrunkReceived Packets w/o ErrorReceived Packets with ErrorBroadcast Received PacketsTransmitted Packets w/o ErrorsTransmitted Packets with ErrorsCollisions
TRK159751901683473751477776778300
TRK239324455620284088439334350100
I can't think why turning STP off would cause a problem. Presumably the router reboots itself after changing STP modes?
If you SSH into the router and turn STP off from the command line does the same problem occur:
# brctl show
bridge name     bridge id               STP enabled     interfaces
br0             8000.f02f749237d8       yes             eth1
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
                                                        eth7
                                                        wl0.2
# brctl stp br0 off
# brctl show
br0             8000.f02f749237d8       no              eth1
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
                                                        eth7
                                                        wl0.2
Obviously your interface names will be different than mine.
# brctl show
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
                                                        eth7
                                                        wl0.2
# brctl stp br0 off
# brctl show
                                                        eth2
                                                        eth3
                                                        eth4
                                                        eth5
                                                        eth6
                                                        eth7
                                                        wl0.2
Here's mine:
# brctl show br0
br0        8000.fc34978b2a58    yes        bond0
                            eth1
                            eth2
                            eth5
                            eth6
                            eth7
# brctl stp br0 off
# brctl show br0
br0        8000.fc34978b2a58    no        bond0
                            eth1
                            eth2
                            eth5
                            eth6
                            eth7
Interestingly after manually disabling STP ... is still working ok.
Here's mine:
# brctl show br0
                            eth1
                            eth2
                            eth5
                            eth6
                            eth7
# brctl stp br0 off
# brctl show br0
                            eth1
                            eth2
                            eth5
                            eth6
                            eth7
Does this suggest that there's a boot problem on the RT-AX86U?
That is, the Eth ports are being enabled before the bridge is created and hence creating a network loop on the Eth fabric?
It does sound like a bug.
You only said the problem was "lose the LAN" which isn't particularly detailed. You could look through the code here (as you're using Merlin's firmware).
On the other hand you could just leave STP enabled as I can't see it doing any harm.
Well, is rather difficult to see what's going on as everything I have is connected to the Eth switch and the RT-AX86U ... I suppose I could enable loopback protection or STP on the HP1810-8G (currently disabled), as it will log the problem and disable the port(s) to keep at least the Eth part of the network going.
@colin and @stephen_d_hill - the default for STP is 'on' - but there is something odd with STP in the off position in some configurations...
in the last few years, I had two configs I'd implemented,that didn't quite behave when turning STP off (assuming the 'help' it was giving me might have been the problem)...
particularly with a managed cisco-switch, I'd configured link-ag on the switch, a nas and the router - flattened/disabled the vlans on the switch and was flipping STP on/off to troubleshoot the problem (an AX88 at the time)...
turned off STP on the asus router to troubleshoot the issue and it bit me on the backside with same symptoms I'm reading here - a reboot and the link-ag wasn't passing packets...
I left the switch config'd and threw an EOL cicso router from my junk pile at the problem and everything functioned as expected... my guess it was a problem with the asus - but at the time I couldn't be bothered messing with it due to time constraints...
I often wondered if the managed switch's STP was set to 'on' which may have created conflicts (just guessing)... this was the second time I encountered an oddity with flipping asus STP on/off...
