vpnmgr let OpenVPN support IPv6 connection (No routing)
zhsrain
Due to the lack of IPv4 public IP address, we hope to use IPv6 to connect OpenVPN to access the intranet. The actual test is available. We only need to modify the protocol
proto tcp-server
To be amended as follows:
proto tcp6-server
Can Merlin add it to the management page?
proto tcp-server
proto tcp6-server
Unfortunately the infrastructure of asuswrt(and asuswrt-merlin) have not advanced enough to support ipv6 over openvpn even though the built in openvpn version supports it. This infrastructure is required to properly handle /establish the routes necessary for ipv6 traffic flow over openvpn.
You would think a router that supports ipv6 connectivity would have established the proper support for ipv6 on openvpn , but this is not the case. We probably have a cloud of "ipv6 protocol is too new" for another 10 years as far as asuswrt is concerned.
In practice, only IPv6 is used for external connection. When OpenVPN is connected, the internal network is still connected with IPv4. This situation has met most of the requirements
From what I gather its not as simple as a single line change this isn't a vpnmgr issue, it is openvpn support itself
it would be nice if we could get the message across to the powers that be that this would be a nice feature to incorporate next as far as openvpn goes either on asuswrt or on asuswrt-merlin. it is a shame that it is just wishful thinking.
I'm sure it will work after modifying tcp6. In addition, I need to modify the firewall or use tap mode. I only use IPv6 to establish the connection, but actually I still run on IPv4 internally
Keep in mind false positive may exist because tcp6-server allows for Anet4 or Anet6 connections, which means even if you specify tcp6-server this could just be falling back to v4 once it realizes there are no v6 routes.
I am already well aware of this. Reality is, adding IPv6 support would be a major project, and I lack both the time and the resources to do such a thing. Starting with the fact that my ISP does not support IPv6, and isn't expected to do so for many years, making it impossible for me to test anything.
Yes I imagine the burden should more direct at asus versus for you to have to take on the burden yourself. You do a great job as is.
Asus and I have separate OpenVPN implementations. While they originally used the Tomato port that I did for Asuswrt, they have since completely rewritten it and made it closed source. We no longer share any OpenVPN-related code (aside from the ovpn import code present in the httpd server).
In China, IPv4 is very rare. It is the demand of most people to establish a connection with IPv6 and then be able to communicate with each other in the intranet
Thank you very much. In fact, I only need OpenVPN which can use IPv6 connection, and I don't need IPv6 Routing rules. In fact, it is still an intranet based on IPv4. So I want to ask if it can be provided to the configuration page as an option
A half-baked implementation would be worse, because then people would be confused as to why some stuff doesn't work properly whenever they are using an IPv6.
