lighttpd and directory listing
kos_tea
Hi all!
I'm facing the following problem:
On RT-N66U (with RT-N66U_378.56_2.trx) i'm running lighttpd whitout problems, but if i try to enable directory listing on a directory (eg: test) i get in browser a blank page with title AiCloud. Logs show:
"GET /smb/css/style-theme.css HTTP/1.1" 404 345 "http://xxx.no-ip.org/test/" "Mozilla/5.0 (X11; Linux x86_64; rv:42.0) Gecko/20100101 Firefox/42.0"
"GET /smb/js/tools.js HTTP/1.1" 404 345 "http://xxx.no-ip.org/test/"
"GET /smb/js/davclient_tools.js HTTP/1.1" 404 345 "http://xxx.no-ip.org/test/"
"GET /smb/js/smbdav-main.min.js HTTP/1.1" 404 345 "http://xxx.no-ip.org/test/"
"GET /test/ HTTP/1.1"
Any hints?
Many thanks!!!
The lighttpd server included in the firmware is customized for AiCloud. I don't recommend trying to use it for anything else.
Was going to try lighttpd-mod-webdav. Will it provide functionality to download upload files?
As I said, the built-in version is customized, and should not be used by anything else than AiCloud. If you need to implement something, you will have to install a clean version of lighttpd through Entware, and use that instead.
Thank you for quick response!
Somehow i resolved my problem by installing openldap openssl libxml2 sqlite.
I think was a dependency problem.
Lighttpd server i am using was installed with ipkg (optware-ng).
