Guys,
Anyone tried this method? Does it actually work? Any side effect to doing this?
Thanks.
http://nwgat.ninja/limit-bandwith-for-ssid-on-asuswrt-merlin/
login to router with ssh/telnet
where wl0.1 is the ssid of your guest network.
will vary if you have configured more than one
to limit to 5mbit until you reboot
tc qdisc add dev wl0.1 handle 1: root htb default 11
tc class add dev wl0.1 parent 1: classid 1:1 htb rate 5mbit
tc class add dev wl0.1 parent 1:1 classid 1:11 htb rate 5mbit
to remove the settings use
tc qdisc del dev wl0.1 root
to limit to 5mbit permanently
echo tc qdisc add dev wl0.1 handle 1: root htb default 11 >> /jffs/scripts/wan-start
echo tc class add dev wl0.1 parent 1: classid 1:1 htb rate 5mbit >> /jffs/scripts/wan-start
echo tc class add dev wl0.1 parent 1:1 classid 1:11 htb rate 5mbit >> /jffs/scripts/wan-start
Note:
Only downstream, i have to figure out upstream
You might need to enable jffs and add them to /jffs/scripts/init-start to be presistent
more info about tc
http://mark.koli.ch/slowdown-throttle-bandwidth-linux-network-interface
Thanks.
Note:
more info about tc
