Linux activation network connection error
Aaron
I recently installed the latest version of Linux onto a 6 years old laptop and it has given it a new lease of life. I am very pleased with it except for one irritating issue. I connected a portable hard drive and a USB stick and transferred some files from the HD to the stick. I unmounted both and removed them. Since then I keep getting the Activation Network connection error message, I can only assume it is trying to connect to either the HD or the USB stick and as neither of them is connected, hence the message. My internet connection is fine and has no issues.
Any help would be gratefully received.
Thanks in advance.
Appuals solution here- https://appuals.com/activation-of-network-connection-failed-in-linux/
"the latest version of Linux" means nothing. Presumably you're talking about a Linux distribution, like Ubuntu, Debian, etc. So which distribution and which release? Can you provide a screenshot of the error message.
OzarkEdge Solved Project: Block ads for all network users... General Network Security 11
