Linux PCs, Servers, Gadgets Can Be Crashed by 'Ping of Death' Network Packets
microchip
The Register reports that it is possible to crash network-facing Linux servers, PCs, smartphones and tablets, and gadgets, or slow down their network connections, by sending them a series of maliciously crafted packets. It is also possible to hamper FreeBSD machines with the same attack. Patches and mitigations are available, and can be applied by hand if needed, or you can wait for a security fix to be pushed or offered to your at-risk device. A key workaround is to set /proc/sys/net/ipv4/tcp_sack to 0. At the heart of the drama is a programming flaw dubbed SACK Panic aka CVE-2019-11477: this bug can be exploited to remotely crash systems powered by Linux kernel version 2.6.29 or higher, which was released 10 years ago.
https://www.theregister.co.uk/2019/06/17/linux_tcp_sack_kernel_crash/
AFAIK, most routers are vulnerable to this. I already passed on the info to NETGEAR and they opened a security bulletin for it. No idea if/when they'll fix it and how (kernel patch or iptables rules)
No, it's a kernel issue. You can send it specially crafted packets and it'll crash
Correct... any correctly formed frame will crash the kernels..
https://isc.sans.edu/forums/diary/What+You+Need+To+Know+About+TCP+SACK+Panic/25046/
My Asus RT-AC68U has sack enabled and tcpdump confirms some of the points in the SANS diary linked above. What do you guys think about the vulnerability for a router? No proofs-of-concept yet, but eye-opening none-the-less. I saw the SANS article first, then came here once I searched for SACK.
Well...
You are vulnerable if you are using a current Linux system, have selective acknowledgments enabled (a common default) and are using a network card with TCP Segment Offload (again, a common default in modern servers).
admin@RT-AC68U:/# ethtool -k eth0 | grep tcp-segmentation-offload
tcp-segmentation-offload: off
