hedly
Hello all. I'm asking for a little help on how to get wireless to a room in my house.
Network.
ATT to their DSL modem. I've turned off their wireless.
Modem to TP-Link AC1750 wireless router
TP-Link wired to DLink 1016D 16port Gigabit switch to various computers, and a file server.
TP-Link wireless to various phones,TV's, stereos, a tablet, and maybe a laptop in the guest bedroom.
The house is set up like this:
Basically the house is 'L' shaped, and roughly 50ft long x 50' deep with 25' wide legs.
House is wooden construction with stucco. There is a brick wall that separates the entrance/living room area from the master bedroom.
The TP-link wireless router is at the red dot.
Purple square is where phone/DSL enters the house and I've run multiple cat5 cables the living room and office.
I get decent WiFi in the Master and toilet (of course). But not in the Guest bedroom. In fact, I recently saw that my wife's iPhone was running 4G instead of the wireless which is why I write.
Question: Is it normal not to be able to get wireless from maybe 40ft away??
- signal goes through 3/4 walls including a brick wall and stucco.
- I can see a couple of my neighbors routers on my phone.
To fix the issue I was just thinking of using an older TP-link router I have as an access point at the light blue dot. Basically in the closet between the guest and kid's room.
- I actually have run a Cat5E cable around the outside of the house into the attic over the bedrooms, so I do have a wired link back to the switch.
- If I did this I assume that I should change the channel(s) so that it doesn't use the same as the primary router. I'd take recommendations on which channels to use.
Any suggestions, comments, recommendations.
Thanks in advance.
hEdly
Network.
Thanks in advance.
hEdly
