Tutorial Asus Dual WAN Router Load Balancing and Failover Router Problems and Fix
OpenSpeedTest
TLDR -> Do a Factory Reset using WPS button.
Load Balancing and Failover working? NO
Load Balancing Working? Yes but not Practical for real-world
usage. [Timeouts, Connection Reset & Total Network BreakDown]
Failover? YES if you spend some time on it. [Setup Static IP, Match MTU from your Router]
Fallback? YES But you need to tune the values depends on the latency and connection reliability.
Here is my DualWan Setup
I spend last few days playing with ASUS DUAL WAN feature.
Load balancing work best when you set 3:1 or 5:1 or 9:1 ratios. That means most of the time you use Primary connection.
But when one connection goes down it will not use the working connection to reroute the traffic. Sometimes it will take 10 to 15 minutes to get proper network on all machines.
result unreliable network!
Load balancing is good enough? NO it's waste of time.
OK Failover is working fine after a FULL factory reset by holding wps buttton for 30 seconds.
To get it working it's better both connection have static ip allocation.
because renewing DHCP will kick Failover for some reason.
Also set Fallback to 40 or 99 times otherwise it will keep interrupt the backup connection.
OK Failover and Fallback working? Yes for the most part.
You can setup a script to update DDNS domain for the wan-event
here is my script for DUCKDNS
// wan-event file
#!/bin/sh
killall "My-DDNS"
/jffs/scripts/My-DDNS $1 $2
// My-DDNS file
#!/bin/sh
WAN_IF=$1
WAN_STATE=$2
SUBDOMAIN="subdomain-name"
TOKEN="duck-dns-token"
if [ "$WAN_STATE" == "connected" ]; then
sleep 5s
IP=$(curl -s 'http://myip.dnsomatic.com/')
sleep 5s
response=$(curl -s "https://www.duckdns.org/update?domains=$SUBDOMAIN&token=$TOKEN&ip=$IP")
sleep 5s
if [ "$response" == "OK" ]; then
logger "DuckDNS Response was [$response]. & Updated IP: $IP"
else
logger "DuckDNS Response was [$response] & Failed to Update IP: $IP"
logger "Trying again by Executing wan-event..."
./wan-event $1 $2
fi
else
logger "WAN Status : $WAN_STATE"
fi
After creating these two files make sure you run chmod a+rx /jffs/scripts/*
Finally I really wish if i can use Load Balancing and Failover at the same time.
@OpenSpeedTest
My experience has been similar to yours with Asuswrt-Merlin Dual WAN.
The Dual WAN - Loadbalancing provides a very basic ROUNDROBIN loadbalancing algorithm, but it is not fit for production implemention. It lacks session stickiness and more advance loadbalancing algorithms (such as LEASTCONNECTIONS, etc) that you'd find with an enterprise level loadbalancer such as Citrix Netscaler or F5 BigIP.
However, I have found Asuswrt-Merlin's Dual WAN - Fail Over functionality useful for production implementation when configured properly.
BTW... If Asuswrt provided more advance loadbalancing algorithms, there would be no need for simultaneous loadbalancing and failover.
Hope that helps provide some prospective.
Respectfully,
Gary
I ended up purchasing a $60 Mikrotik router.
here is what it can do.
Continuous ping
Live Streaming
But i use my AC5300 in front of my Mikrotik router. Because we all know asus UI is very user-friendly and easy to manage everything.
Yes, asus should learn from Mikrotik and other who do Dual Wan very well.
@OpenSpeedTest
Seems like a nice, cost-effective, hardware workaround. How stable/reliable do the combination seem to be?
Would you provide a little more detail regarding your topology between the AC5300 and Mikrotik? ISP1 plugs where? ISP2 plugs where? How do the AC5300 and Mikrotik plug together?
Thanks for sharing!
Gary
I port forward from both of my ISP to AC5300.
It's pretty easy
Port Forwarding for ISP 1
Firewall >> NAT
Chain : dstnat
dst address : 192.168.0.3
protocol : 6(tcp)
Dst Port : 8080
>>Action
dst nat
to Address : 192.168.100.3 [LAN IP]
to Port : 8080
Port Forwarding for ISP 2
Firewall >> NAT
Chain : dstnat
dst address : 192.168.20.3
protocol : 6(tcp)
Dst Port : 3389
>>Action
dst nat
to Port : 3389
Here is my Full Config.
# jul/20/2021 13:38:32 by RouterOS 6.48.3
# software id = BY5Y-GDY1
# model = RB750Gr3
# serial number = XXXXXXXXXXX
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip firewall connection tracking
set enabled=yes
/ip address
add address=192.168.100.1/24 interface=ether5 network=192.168.100.0
add address=192.168.0.3 interface=ether1 network=192.168.0.1
add address=192.168.20.3 interface=ether2 network=192.168.20.1
/ip dns
set servers=8.8.8.8,8.8.4.4
/ip firewall filter
add action=drop chain=output disabled=yes dst-address=8.8.8.8 protocol=icmp
add action=drop chain=output disabled=yes dst-address=8.8.4.4 protocol=icmp
/ip firewall mangle
add action=accept chain=prerouting dst-address=192.168.0.0/24
add action=accept chain=prerouting dst-address=192.168.20.0/24
add action=accept chain=prerouting dst-address=192.168.100.0/24
add action=mark-connection chain=prerouting in-interface=ether5 \
new-connection-mark=ISP1 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:3/0
new-connection-mark=ISP2 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:3/1
new-connection-mark=ISP3 passthrough=yes per-connection-classifier=\
both-addresses-and-ports:3/2
add action=mark-routing chain=prerouting connection-mark=ISP1 in-interface=\
ether5 new-routing-mark=ISP1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=ISP2 in-interface=\
ether5 new-routing-mark=ISP2 passthrough=no
add action=mark-routing chain=prerouting connection-mark=ISP3 in-interface=\
ether5 new-routing-mark=ISP3 passthrough=no
add action=mark-connection chain=prerouting in-interface=ether1 \
add action=mark-connection chain=prerouting in-interface=ether2 \
add action=mark-routing chain=output connection-mark=ISP1 new-routing-mark=\
ISP1 passthrough=no
add action=mark-routing chain=output connection-mark=ISP2 new-routing-mark=\
ISP2 passthrough=no
add action=mark-routing chain=output connection-mark=ISP3 new-routing-mark=\
ISP3 passthrough=no
/ip firewall nat
add action=dst-nat chain=dstnat dst-address=192.168.0.3 dst-port=8080 \
protocol=tcp to-addresses=192.168.100.3 to-ports=8080
add action=dst-nat chain=dstnat dst-address=192.168.20.3 dst-port=3389 \
protocol=tcp to-addresses=192.168.100.3 to-ports=3389
add action=masquerade chain=srcnat src-address=192.168.100.0/24
/ip route
add distance=1 gateway=192.168.0.1 routing-mark=ISP1
add distance=2 gateway=192.168.20.1 routing-mark=ISP1
add distance=1 gateway=192.168.20.1 routing-mark=ISP2
add distance=2 gateway=192.168.0.1 routing-mark=ISP2
add distance=1 gateway=192.168.0.1 routing-mark=ISP3
add distance=2 gateway=192.168.20.1 routing-mark=ISP3
add distance=1 gateway=8.8.8.8 target-scope=30
add distance=1 gateway=8.8.4.4 target-scope=30
add distance=1 dst-address=8.8.4.4/32 gateway=192.168.20.1
add distance=1 dst-address=8.8.8.8/32 gateway=192.168.0.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Kolkata
/system ntp client
set enabled=yes primary-ntp=192.46.215.60 secondary-ntp=162.159.200.123 \
server-dns-names=8.8.8.8
/tool bandwidth-server
set enabled=no
/tool netwatch
add down-script="ip route disable [find dst-address=0.0.0.0/0 gateway=192.168.\
20.1]\r\
\n/ip firewall connection remove [find connection-mark=\"ISP2\"]\r\
\n:log error \"ISP2 down\"" host=8.8.4.4 interval=3s timeout=300ms \
up-script="ip route enable [find dst-address=0.0.0.0/0 gateway=192.168.20.\
1]\r\
\nlog error \"ISP2 up\"\r\
\n/tool fetch url=\"https://go.vishnu.pro/BSNL\" keep-result=no"
0.1]\r\
\n/ip firewall connection remove [find connection-mark=\"ISP1\"]\r\
\n/ip firewall connection remove [find connection-mark=\"ISP3\"]\r\
\nlog error \"ISP1 down\"" host=8.8.8.8 interval=2s timeout=500ms \
up-script="ip route enable [find dst-address=0.0.0.0/0 gateway=192.168.0.1\
]\r\
\nlog error \"ISP1 up\"\r\
\n/tool fetch url=\"https://go.vishnu.pro/Asianet\" keep-result=no"
@OpenSpeedTest
Nice! Proxy and RDP forwarding. Why did you settle on Mikrotik instead of a competitor?
Thanks, again.
Gary
I was just a click away from buying an Intel Mini PC with 6 LANs from Alibaba. It will take more than 15 days and cost me 500 to 600$. Luckily someone from Reddit shared his experience with Mikrotik when I posted a question about dual wan failover and load balancing. that gives me enough confidence, and it was already available online store where I live and cost me around 60$.. so I told Alibaba rep. to hold my order for a week, and I purchased this. Still, I have not completed that order and going to put that money to buy a NAS :) maybe DS920
Edit : I was planning to use that Mini Pc for PfSense
@OpenSpeedTest
I appreciate you sharing the details of your cost-effective, alternative loadbalancing solution.
Perhaps, one day, Asus will provide a Dual WAN - Loadbalancing offering that's actually usable in a production network.
Until then... Enjoy your Mikrotik and bonus Synology solutions.
Respectfully,
Gary
@OpenSpeedTest, thanks for sharing your configuration with the Mikrotik router. I found the exact same issue with ASUS dual-WAN especially with sticky sessions. I bought the RB750Gr3 as well and was following your config file but had a few questions.
1. What is ISP3 as your diagram shows two WAN's?
2. How did you connect the Mikrotik to the ASUS? I am going to guess as a static IP to the WAN port of the AC5300 but want to confirm.
I use AIMesh and VPN on the ASUS for specific devices so hoping that will remain with the Mikrotik in place.
I appreciate your help.
Thanks!
Thanks!
1) One of my connection is 150Mbps and another one is 60Mbps. Later i created on more rule for ISP1 to make sure it will be used more often because it have more available bandwidth
2) Yes, it's a static ip configuration in ASUS and MikroTik
If you enable portForwarding in Mikrotik to ASUS IP. Every will work normally.
You never really see the hardworking MikroTik box Everyday.
You will have 24x7 Internet on your ASUS router.
I am Still using this config and very happy with the setup.
last month one of my ISP call me and Explained about the reasons for random interruption occurred to the service for last 3 days.
Some maintenance work going on bla bla bla / optical fiber breakdown etc.
But i never noticed that issue. And i told him i got a second connection and LB/Failover using Mikrotik..
It is working that good for me.
Thanks @OpenSpeedTest!
I understand what you did and it was really helpful. I've been using this setup for a little over a month and it is absolutely solid. I would suggest this for anyone who wants to do a any complex networking that the residential routers don't handle very well. For the price, the Mikrotik is really awesome. It isn't the easiest thing to set up but with people like OpenSpeedTest who share their knowledge, it is great. If anyone needs any help, please ask and I'll be happy to give some input!
@therealrav @OpenSpeedTest
I have the same dual WAN failover/failback issues with my RT-AC88U (with AIMesh enabled) and after reading the above ordered the hEX RB750GR3. So not yet any experience with WinBox/RouterOS. Device will be delievered tomorrow ...
My connections are Cable 1000/40 (Automatic public/dynamic IP from DOCSIS 3.1 cable modem) and Fiber 1000/50 (PPPoE). No VPN server, no IPTV (yet). Some port forwardings, eg. to Synology NAS.
I have some questions in relation to the general setup, in particular for not losing the AIMesh functionality. Do you keep the ASUS in Wireless Router mode, with no essential changes except the WAN side? Or do I best reconfigure the ASUS in "AP mode/AiMesh Router in AP mode"? Is DHCP server enabled on the Mikrotik or on ASUS? If on Mikrotik only, how does the ASUS allocate the (fixed?) IP's for the AiMesh clients?
Thanks in advance for any input/advice !!
Correct... You can keep the Asuswrt in Wireless Router Mode. Configure your Asuswrt-Merlin WAN interface with a Static Private IP Address, which you will Overload NAT to from the Mikrotik.
Wireless Router Mode should be fine.
Is DHCP server enabled on the Mikrotek or on ASUS?
I would recommend continuing to use DHCP on your Asuswrt-Merlin Wireless Router and disabling DHCP on the Mikrotik.
If on Mikrotek only, how does the ASUS allocate the (fixed?) IP's for the AiMesh clients?
DHCP IP Address assignment should be performed by the device managing the routes and subnetworks, and the reason for the previous Asuswrt-Merlin recommendation.
The real question is... What are you going to do with a 1Gbps/1Gbps Multiplexed Internet Connection? TorFarm? BotFarm? :)
You'll need some serious hardware to take advantage of such a connection.
Enjoy!
Gary
Correct... You can keep the Asuswrt in Wireless Router Mode. Configure your Asuswrt-Merlin WAN interface with a Static Private IP Address, which you will Overload NAT to from the Mikrotek.
I would recommend continuing to use DHCP on your Asuswrt-Merlin Wireless Router and disabling DHCP on the Mikrotek.
Enjoy!
Gary
@garycnew
Thanks for all the useful input!!
On the real question: the second connection was just a backup line, but was upgraded to gigabit for less than 4$ per month. The first connection, Telenet, is getting notorious for local connection ruptures. Also on the second one, there are regular disconnections. With two university students 'studying at home' and two other persons working from home, due to the health measures. 2 x 1GB could be indeed fantastic, if stable. Yesterday my daughter had an exam at home, with obligatory use of the 'Respondus Lockdown Browser' (which lock downs your pc for everything except your exam browser screen - you cannot even change your Network and Internet settings ...). In the middle of the exam: disconnection on first connection. No failover switch made. Luckily after 10 minutes connection back up ... Not an ideal situation.
@garycnew
High-Availability at home is almost becoming a necessity in this day and age. Mikrotik should be a great solution for your needs. If upgrading to gigabit is only $4 more per month, I'd probably go the same route as well. An alternative for redundant Internet could be 5G mobile terminated at the Mikrotik. Additionally, you might want to think about Mikrotik, Asuswrt, UPS, Power Generator, Hot/Cold-Failover/Backup Devices in case of hardware failures within the premises.
Let us know how your Mikrotik solution works out.
Respectfully,
Gary
