hello guys, i have asus ax88u with merlin fw. my downlaod speed is 920mb but if i connect my pc to asus router ax88u without vpn download speed is 850-870mb but if i connect my pc with express vpn my downlaod speed is only 170mb. why??? i lose speed with my router asus
VPN client download speeds tend to vary more than just a straight WAN connection. Just more moving parts. ( See screen shot below.)
Also IMHO given the economics of the commercial VPN providers they really can't afford to offer higher speeds for $3 - $7 per month. If your getting 200+ Mbps downloads that is good as it is going to get currently.
To prove to yourself it isn't a limitation of your router (assuming it supports AES-NI) install a VPN client from your VPN provider of choice on a PC wired to your router, turn off the VPN client on the router and run a speed test.
Because your own router does something your ISP router doesn't, perhaps? Disable all TrendMicro components on the ASUS router, all User Scripts, all USB services, etc., turn it into a straight routing device and test again. You purchased the ASUS router to be able to do more things on it, not available in ISP router, I guess.
