brailyne59
Hello everyone at SNB
I'm looking to maximize performance of streaming from a local Xbox One X server on ethernet to a wireless (wi-fi AX 2x2, surface laptop 3) client.
The data used for this is about 20mbps for 1080p/60fps.
My network configuration:
From looking at data on SNB:
Based on the Router Ranker, the NETGEAR Nighthawk X4S (R7800) has the best average downlink speeds (and #1 at many other metrics)
Based on the Router Charts, the ASUS AC2600 has the best 5ghz minimum downlink speeds, followed by the X4S. The best 2.4ghz minimum downlink speeds go to the Phicomm AC 1900.
What I've tested so far:
So far I've compared the WRT3200ACM performance to a Netgear RAX200. The RAX200 performs significantly better, however, the biggest problem with it is that it's not ready yet and very unstable.
I'm wondering which metrics are best to compare for my target use case, and if these AC routers provide a more stable connection at range than any of the AX routers.
Thank you in advance!
- Current router is a Linksys WRT3200ACM
- ~20 clients, a few active at the same time
- Not too much wifi channel interference from neighbors
- Target primary client is at a range of 55 feet and beyond one inside sheetrock wall
