Moving from Optware to Entware....
CondorUK
...is it as easy as installing Entware, deleting the asusware.arm folder created by Optware on the external hard drive and re-installing any applications?
The other way around. Remove all traces of Optware before you install Entware.
RMerlin - Is there an uninstall approach you would recommend....or is it as simple as uninstall anything that was installed by it and deleting the folder?
As I said, delete the asusware folder BEFORE you install Entware.
Rebooting between the two operations is probably required. Beyond that, nothing special really. Don't forget that Entware uses opkg and not ipkg.
