Hi guys! 1)The situation is following: a house with 3 floors. On each floor there are few ethernet sockets connected to a switch and a router on the 1-st floor. I want to organize wifi network with many APs. All rooms on each floor are connected by a hall (L-shaped). But ethernet sockets are located in the rooms (and only some of them) therefore wifi signal degrades because of walls. To solve this situation I want to put wifi APs in the hall, two on each floor by the use of powerline adapters.
As I understand if I put one powerline adapter near router on one lan port and then pair all other powerline adapters with it, the signal quality on the third floor will be very bad.
But I have separate ethernet sockets on each floor.
The question is can I put separate powerline adapters pairs on each floor? Each pair will then be connected to a different ethernet socket. But considering they are on the same electrical wiring will there be any interference with each other and a resulting bandwidth decrease?
If not maybe I can even use two different pairs on each floor? One pair will be in one side of the hall connected to a nearby room ethernet socket and the other in the other side of the hall connected to a different room socket?
2)Is using wifi extenders/repeaters a better alternative?
