Paradise
Ok i did read 802.11n products will not increase wireless LAN range.
But has b/g a better range?
I have an old Netgear DG834GB (this thing is ~11 years old) and the range is better with every device i check the range with compared to Netgear WNDR4300 and TP-Link TL-WDR3500 at 2.4GHz N.
I also hat a ASUS Dark Knight because of all the good reviews but range was not better.
I sold the Asus because of the 10 watts power consumption and was looking for devices that consume less because there is no way i have good WLAN over two floors with just one AP.
The Netgear and TP-Link together consume less power then the Asus alone.
Yes i life in a German house with 14" stone walls and concrete ceilings with allot of steel
But i wonder why the old DG834GB b/g range is better?
N and b/g are both 2.4GHz so there should be no difference?
The other question is about WPA/WPA2 mixed mode.
I have some old devices that only support WPA-PSK (TKIP i guess).
If i chose mixed mode in the AP does that mean that devices that support WPA2-PSK (AES) always chose this higher encryption?
