NAS - RT-N66U, transfer speeds [wired vs. wireless]
Discussion in 'ASUS N Routers & Adapters' started by mmmmmm, Dec 3, 2012.
  1. mmmmmm
    mmmmmm Occasional Visitor
    Nov 29, 2012
    38
    HI,
    I have s simple (and possible stupid) question.
    I am copying files from my laptop to a NAS.
    The NAS is a D-LINK 343 with gigabit ethernet card.
    Latop is a Dell Studio with network adapter "Realtek RTL8168D/8111D Family PCI-E Gigabit Ethernet NIC".
    Using wired (Laptop, RT-N66U, NAS) I am getting the following speeds:
    - Write: 182Mbps
    - Read: 395Mbps
    When connecting the laptop using the wireless adapter (IntelĀ® Ultimate N WiFi Link 5300 AGN, 450Mbs, 3 antennas), the same operations slows considerably:
    - Write: 97Mbps
    - Read: 73Mbps
    The windows shows the wireless connection established at 450Mbps.
    Router is configured for the 5GHz band, 40Mhz, 44 control channel.
    Is it unrealistic from my side to expect at least the same (182Mbps) when using wireless also?
    182Mbps is ~22MB/s which seems just a fraction from the total of 450Mbps that both the Asus RT-N66U and Intel Wifi adapter advertise.
    If I'm talking nonesens, I appologise. Please take into account that I have just basic basic knowledge about wireless networks.
    Thank you.
  2. Log in / Register to remove this ad
  3. mmmmmm
    Nov 29, 2012
    38
    more details
    Router and laptop are in the same room.
    Laptop's wifi adapter settings:
    • 802.11n Channel Width for band 2.4: Auto
    • 802.11n Channel Width for band 5.2: Auto
    • 802.11n: Enabled
    • Fat Channel Intolerant: Disabled
    • Mixed Mode Protection: CTS-to-self Enabled
    • Preferred Band: Prefer 5.2GHz
    • Throughput Enahancement: Enabled
    • Transmit Power: Medium-High
    • Wireless mode: 802.11a
    NAS
    • Netowrk card Link Speed is set at 1000Mbps.
    Router RT-N66U settings:
    • only 5.2GHz radion on
    • control channel: 44
    • bandwidth: 40Mhz
    • encryption: tried with no encryption also
Share This Page
