I have a 2 story home (ground floor + 2 more floors) with my office on the top floor. I have never been able to obtain a good signal on the ground floor (solid Swiss house). Tried a repeater, little improvement. Tried Powerline wireless adaptors, not any change. The following is what I have worked out and it is functioning well.
A friend loaned me his new Netgear R6300 ac router. I disconnected my old Linksys WRT54G and connected the Netgear to my modem. I plugged my main Powerline adaptor into the Netgear R6300. On the ground floor I converted the old Linksys router into an access point and plugged it into the secondary Powerline adaptor.
It functions well and I get a great wireless signal on my laptop (wireless N) and the Internet is fast. I can access my desktop on the network in the top floor open files with little or no latency. My Nexus 7 and Samsung Galaxy S (wifi only) are showing a much better signal but only about 35% that of the laptop. My wife's iPad 2 gets a signal about 50% of the laptop.
Now the question for all of you. I must return the Netgear to my friend. I have no intention of buying one of the new AC routers but need to buy a router to replace the loaner. I have read the Sticky on mixing N and legacy clients and understand that performance will be reduced if they are transmitting at the same time. There is one point on which I am a bit confused however.
In the article linked to the sticky it states the following: " . . . . make sure the draft 11n router is using the 11g friendly 20 MHz bandwidth mode". Why should I buy an N router if it should be set back to the 11g 20 MHz bandwidth mode? Wouldn't I be better off just buying another G router?
So, I need a few recommendations:
1. Should I buy a G rather than a N router?
2. If there is a legitimate reason for buying a N router, should it the main router or the access point?
3. If I should buy the N router which ones have dual radios. The article also stated the following: " ... If N clients are associated with one radio and legacy clients are associated to the other radio, you won't see reduced performance."
Paul
Paul
