Bruce White
I just purchased 2 of the RT-AC68P routers from Best Buy. I know the routers can be set up in one of four modes--wireless, repeater, bridge or access point. I have one router directly connected to my Comcast cable modem. The other will go to another room to provide wireless access to several devices that don't have built in wireless. I'll cable them to the router.
I cannot cable the two routers together.
My question is with the second router--should I configure it in bridge mode or access point mode? From reading I've been doing on this forum, I understand that repeater mode will cut my wireless speed in half, but bridge mode will allow full speed but no other wireless connections except to the main router. What about access point mode, though?
I suppose I could put the second router in either bridge or AP mode for a while to test it and then switch it to see if I find any differences.
Any suggestions? I've given some thought to getting the Zyxel 1000 Mpbs powerline kit to connect the routers but would like to avoid that expense if possible.
Thanks in advance for any suggestions!
Bruce
PS--my previous setup was a Cisco EA3500 as my main router and a Trendnet TEW-640MB as a media bridge. However, I frequently lost connection between the two. Sometimes connection would be restored if I rebooted the Trendnet. Other times I had to hook it up to a laptop to reconfigure it.
Bruce
