Hi there,
I am not sure if this is the right place to post this question, so I apologise if it does not belong here.
I have been having trouble with hackers in the past two weeks, using up all of my internet. I think that this is the case because I have internet trackers on all the devices that I have been using, and the total amount recorded by my internet trackers does not add up to the amount that my internet provider says that I have used (by a long shot). The extra usage is mostly uploads, 500 - 700 mB per hour, every hour, even when we're asleep, or at work.
I have changed my password, several times, but they keep getting back in. I also rang up my internet provider - they told me that it was my fault, but they changed my IP address. I have also been looking online for tips, and found that I should disable WPS, which I have done. I have also disabled SSID broadcasting.
I have a Netcomm N300 modem, which is attached to another box labelled Cisco DPC3008, which is plugged into the wall. I turned off the Netcomm N300 last night, and it was off until I got home from work today, but my internet provider still says that I used 150mB of downloads in that time (but no uploads). I don't understand how anything could have been downloaded if the wireless modem was switched off.
I have also been looking through the advanced settings of my modem, to see if there is anything else that should be enabled/disabled to make my network as secure as possible. I have tried to use google to figure out what these things mean, but I am unsure:
The following settings are DISABLED: Dynamic DNS, Qos, SNMP, Dynamic routing and static routing, TR-069.
The following setting is ENABLED: IPv6
If you have any recommendations on how I can make my internet as secure as possible, I would be hugely grateful. In the country where I live, internet often has data caps, so I am charged extra for every Gb I use above 80Gb a month. So this has really been stressing me out, because I can't afford to pay for someone else to be illegally using my internet.
I also wonder if, once they'd hacked it once, that made it easier to get back in again? The first time I changed the password, it took three days before they got back in, but I changed the password again last night, and they seemed to get back in within a few hours.
Thank you in advance for any help you can give,
Claire.
Claire.
