cpu
Been fighting with this since I upgraded my AC68U to 378_50. Thought the problem might be the AC68U so I replaced it with a AC3200 just to have the same issue. The AC3200 is brand new and it's first version was 378_52_0 and it's on 378_52_2 now.And yes, I did a factory reset on both boxes
I have isolated the AC3200 with an ASUS gigabit switch because it was taking down my entire network every time it went down making it hard to see the issue. I have also moved DHCP to a Fedora machine, turned on Syslog on the Fedora box and pointed the AC3200 at it.
Everything seems to be working, Syslog messages showing up as expected, default level because this takes over three days to show up, actually pretty predictable, it may have happened in as little as two plus days but this last time the AC3200 showed an uptime of 3 days, 14:22 about 20 minutes before disappearing.
Nothing shows up in Syslog(at the time of failure) or the logs on the AC3200(That I can see). The AC3200 has Internet and WAN lights blinking but you can't ping it from the WAN side so I haven't a clue what it's doing. I power cycle the AC3200 and everything returns to normal for another 3+ days.
Everything is pretty vanilla on the AC3200 with no Guest networks and AIProtection turned on but not much else. All Wifi stops responding when the WAN goes down, stopped using it a while back, for now, have an AC66U in the network setup as an AP that does all the Wifi.
I suspect Syslog is probably useless if the WAN interface can't talk to the Fedora machine. Any suggestions on how to get some information on why the AC3200 stops responding ?
