System Error Message
Part of the Furniture
It seems that my 10Gbe NICs have arrived much faster than i thought and i havent had all the systems up and running(i found 2 not working) however while i do that please reply on what you would like tested.
Currently i have a mikrotik CCR1036 and a ubiquiti edgerouter pro but i can test other routers if supplied with them. I am making a program to perform the tests so i would like to know what tests you would like performed. The software will be in java and will use all the hardware resource it can for tests (meaning multi threading and all that other fancy stuff so it will even run on ARM)
Heres the list of what i've currently planned:
NAT throughput
PPTP VPN throughput (for other VPNs i will need configs to get them working)
Connection flood test
CPU stress test (on some routers full CPU usage can cause reboots)
CPU stress test while performing NAT and firewall
QoS and firewall test based on configs sent by users.
Among the other things that can be tested can be are x86 platforms as routers and in the future GPUs if i get time to write code for them.
Currently i have more than 40Gb/s of NICs
NAT throughput
