netflix broken with RT-AC87U_3.0.0.4_378.52_alpha4.trx - fixed
There is nothing to be "broken" in a router's firmware there. Netflix is just a standard Internet connection. If you are unable to connect to Netflix then check your account and your client's configuration.
I was thinking it was a upnp bug. I also have the same issue on other networks that won't load. Just netflix is the most popular. Another scenario is that something is creating so much lag it is impossible. The only change I had to make was the firmware to fix the solution.
Tried alpha3 and 4 on 87U - both wired and wireless - no problems with any streaming services including Netflix.
Seems my issue was solved by unplugging the router for a few minutes. A hard reset is needed after QTN upgrade. Too bad we can't just have a 'halt' command that would do it.
