pinkfloyd1173
I just picked up this R7500 a few days ago, I am coming from having the asus AC87R router which is a good router dont get me wrong but I was having major issues with my 4 gaming consoles. I tried merlins FW and all the beta FW they came out, which in my opinion broke more stuff then it fixed, I just got tried of it.
Anyways I have about 14 devices that are on my wifi and 4 that are hard wired. The issue that I am having is that if I enable QOS on this router, I take a big hit on my speed tests for some reason. I have TWC 300 down 20 up. Now on the asus router if I enabled QOS or did not use QOS I would still get the same results from my speed tests, 322 down 22 up.
With the R7500 and QOS enabled my speed tests are 120 down and 10 to 15 up with out the QOS I get my regular speeeds 322 down 22 up.
So I am wondering why is it that with this router I take a big hit on my speeds when QOS is enabled. I like to use the QOS because we play alot of online games and we would benefit from the QOS.
Also with the speeds that I have do I really need QOS, the R7500 manual says that if I have speeds above 250 then QOS is not needed???
Let me say this I do not have any usb devices connected to the router, dont really use those features.
My set-up
Cable Modem: Motorola SB6183
Router: Netgear R7500
Well hope someone can give me some advice or lead me in the right direction, maybe I have some settings wrong dont know
thanks for you help guys.
[/URL][/IMG]
My set-up
