New Asus RT-AC56U 802.11ac Gigabit DualBand Wireless Router
Discussion in 'ASUS AC Routers & Adapters' started by RTN, Feb 10, 2013.
  1. RTN
    RTN Regular Contributor
    Jun 9, 2012
    71
    [​IMG]
    Next Gen Connectivity for Fastest USB 3.0 Sharing
    • Wireless-AC1200 2.4GHz & 5GHz concurrent dualband gigabit router
    • Up to 876Mbps + 300Mbps wireless transmission
    • Higt-Powered antenna 150% expanded signal coverage
    • Asus AiCloud service: access, stream, share, sync - all on the go
    http://www.youtube.com/watch?v=KqL4FXuEFKw
    http://forums.vr-zone.com/hardware-...networking-products-announced-ces-2013-a.html
    http://forums.hardwarezone.com.sg/i...-products-announced-@-ces-2013-a-4053089.html
    httр://campuslife.asus.com/index/10637/ces-2013-new-asus-networking-solutions/ :rolleyes:
    http://www.taiwanexcellence.org/index.php/awards/nowdt/content/3/1/102112AB-A040
    Asus RT-AC56U Firmware ASUSWRT version 3.0.0.4.330/332
    ftр://ftp.asus.com.tw/PUB/ASUS/wireless/ASUSWRT/RT-AC56U_3004_332.zip 23433 KB 29.01.2013
    ftр://ftp.asus.com.tw/PUB/ASUS/wireless/ASUSWRT/RT-AC56U_3004_330.zip 22560 KB 22.01.2013
    Linux kernel 2.6.36.4 (brcmarm) - CPU BCM4708 (1 GHz ARM Cortex-A9 Dual-Core) :confused:
    Asus RT-AC56U BCM4708 + BCM4352 2 x 2 802.11ac 867Mbps (5GHz) + 300Mbps (2.4GHz)
    Asus USB-AC53 BCM43526 USB port 2 x 2 802.11ac 867Mbps (5GHz) + 300Mbps (2.4GHz)
    Asus PCE-AC66 BCM4360 PCI Express 3 x 3 802.11ac 1300Mbps (5GHz) + 450Mbps (2.4GHz)
    • BCM4360 supports PCIe interface and implements 3-stream 802.11ac specifications, and reaches speeds up to 1.3 Gbps.
    • BCM4352 supports PCIe interface; implement 2-stream 802.11ac specification to reach up to 867 Mbps.
    • BCM43526 supports USB interface; implement 2-stream 802.11ac specification to reach up to 867 Mbps.
    • BCM43516 supports USB and reaches speeds of up to 433 Mbps with its single stream 802.11ac implementation.
    http://www.broadcom.com/press/release.php?id=s637241 :rolleyes: http://www.smallnetbuilder.com/wire...ed-up-socs-to-power-up-draft-80211ac-products ;)
  2. Log in / Register to remove this ad
  3. Shikami
    Shikami Senior Member
    Apr 12, 2011
    279
    At least this is based on a kernel that doesn't have a soft IRQ issue, I do believe. Too bad it is not the recent dual core processor with uber acceleration. Nice to see PCIe 2.0 being utilized.
  4. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    16,633
    Canada
    Guess the cat is out of the bag now :) I first saw references to the RT-AC56U a few weeks ago in the GPL code.
    ARM based is interesting. That might explain why there's now an ARM directory on their new Asusware repo - at first I thought it was for a NAS.
  5. RTN
    Jun 9, 2012
    71
    RT-AC67U 802.11ac DualBand Wireless-AC1900 Router
    [​IMG]
    http://www.taiwanexcellence.org/index.php/awards/nowdt/content/6/1/102116AB-A040
    http://www.taiwantrade.com.tw/CH/download/1586061 :rolleyes:
  6. RTN
    Jun 9, 2012
    71
  7. huotg01
    huotg01 Senior Member
    Feb 3, 2013
    424
    Montreal
    Should it work with your version of the ASUS firmware ?
    GH
  8. RMerlin
    Apr 14, 2012
    16,633
    Canada
    No. Totally different architecture. Even the CPU instruction set is different (ARM instead of MIPS). Do not even try to flash it!
  9. Sparxxx
    Sparxxx Regular Contributor
    Jan 24, 2010
    61
    Hmmm... so the RT-AC67U will be top of the line model?
    What are the main hardware changes compared to AC66U? Besides the looks :).
    Different CPU? Antenas etc?
  10. huotg01
    Feb 3, 2013
    424
    Montreal
    Is this architecture the new direction for ASUS routers ?
    GH
  11. RMerlin
    Apr 14, 2012
    16,633
    Canada
    The architecture change isn't a decision from Asus, but from the SoC maker (Broadcom), and for this particular SoC. So it depends on which SoC Asus chooses to use for a given router.
  12. AltF4
    AltF4 Occasional Visitor
    Feb 27, 2013
    44
    I wonder if it is going to run less hot?
    My AC66U is pretty hot to the touch.
  13. admiral2145
    admiral2145 Regular Contributor
    Jan 1, 2013
    160
    Does anyone have this router or can someone know if the usb 3.0 transfers at full speed? I currently have a 3tb external hdd usb 3.0 and it transfers around 16 megabytes a sec...
    Sent from my SCH-I605 using Tapatalk 2
  14. RMerlin
    Apr 14, 2012
    16,633
    Canada
    AFAIK that router isn't on the market yet.
    I highly doubt it will be able to push up to 4 Gbits/s off a USB disk, considering the CPU inside the router. Current USB 3.0 routers can barely hit 300-400 Mbits.
  15. admiral2145
    Jan 1, 2013
    160
    Its better than the 125 mbit i get from the ac router..
  16. RMerlin
    Apr 14, 2012
    16,633
    Canada
    I'm talking about disk performance, not wireless throughput.
  17. admiral2145
    Jan 1, 2013
    160
    I get about 15 megabytes a sec to my external 3.0 3tb hdd...
  18. RTN
    Jun 9, 2012
    71
    Asus RT-AC50U/56U/67U
    Asus RT-AC56U Router Preview :D CES 2013 Day 0 - ASUS Networking Products (3:30)
    http://wikidevi.com/wiki/ASUS_RT-AC56U :cool: http://www.hub.ru/wiki/Devices_ASUS_WL_Routers#RT-AC
    http://www.downloadmb.com/news/computer-utilities/system-utilities/asus-new-routers-13-gbps/ ;)
  19. RMerlin
    Apr 14, 2012
    16,633
    Canada
    The RT-AC67U looks like the successor to the RT-AC66U. Would love to see how the ARM CPU handles itself compared to the current MIPS ones.
  20. maylyn
    maylyn Regular Contributor
    Dec 24, 2012
    76
    Exactly :D
    I'm going to keep pestering ASUS Singapore in return pester ASUS Taiwan HQ for one set of ASUS RT-AC56U for a early preview
  21. RTN
    Jun 9, 2012
    71
    Asus RT-AC68U
    RT─AC67U - ARM CortexA9 DualCore 1GHz :rolleyes:
    RT─AC68U - ARM CortexA9 DualCore 800MHz? :confused:
    http://www.mobile01.com/topicdetail.php?f=110&t=3297937&last=43094408 ;)
    http://forums.hardwarezone.com.sg/75025090-post25.html :cool:
Share This Page
