Craig DuVarney
I am currently building our second home/retirement home in the White Mountains of New Hampshire. In addition to setting up a wireless network, I would like to setup a whole home audio system based the design by Ken Rockwell (http://www.kenrockwell.com/apple/how-to-create-a-whole-house-music-system.htm). This design calls for an Airport Express in each room, which would be connected via Ethernet cord to a switch (which would then plug into a router). The Airport Express would also be connected to a small 50-watt amp (AudioSource AMP-100) in each room. From there a user could use an iPod Touch/IPad/IPhone or Wireless PC Tablet/Laptop with iTunes or TuneBlade to steam music to each one of rooms.
I have already purchased the 12 Airport Expresses and the 12 AMP-100s needed for each of the zones. However, I don’t know what to do about the router. The design referenced above calls for an Airport Extreme. In this case the Airport Expresses would be programmed to seamlessly extend the wireless network, which I believe is also called a roaming network. I am a bit concerned about using the Airport Extreme as the router because (a) I don’t use Macs, only an iPod Touch for my music, (b) the tests on SNB show the performance of the Airport Extreme to be lower than other similarly priced routers, and (c) I need to be able to run my VoIP business phone, multiple laptops, and a couple Roku’s via this router, and I am not sure how setting this up on the Airport Extreme would compare to a traditional router. Also, I may want to add some “SmartHome” features to this setup, such as temperature and moisture monitoring, a hard-wired or wireless weather station, etc.
My other option (I think) would to configure the Airport Expresses simply for streaming music via Airplay, still hard-wire them via the switch to the router, but not use them to extend the network. Instead of the Airport Extreme as the router I could purchase something like a “NetGear R7000 Nighthawk AC1900” instead. I am guessing that this router would have enough power to cover a 3000-3300 sq. ft. home, but I do have large steel beams and a large rebar-enforced concrete wall on the back of the house, since the home is built on the side of a hill. I am not sure if this would interfere with the wireless network. If there were dead areas, I see that NetGear sells network extenders. I have never used one of these, but I guessing they would solve that potential problem, and extend the network much like the Airport Express would extend the Airport Extreme.
Also, I know NOTHING about Ethernet switches. I also don’t know how many Ethernet lines I should run to each room. I am going to need at least one per room for the Airport Express, but I am not sure if I should run a second line just to be safe. Of course, this will affect the number of ports I need on the switch, but beyond that, I don’t know what specs I need to look for in an Ethernet switch. My guess is that a very basic Ethernet switch, but I don’t know which one to buy or what to look for, based upon my design.
If someone on this forum could help me with my questions and/or “point me in the right direction”, I would really appreciate it. Also, let me know how I can support this site, as I would like to give back since this site has been incredibly helpful. Again, thank you in advance for your help!!
