I am moving to a new place which has a fiber connection and I am planing to take full advantage of that. So now I am deciding on how to setup my new network and while researching some products some questions arose.
First some information about my current situation:
-the fiber-optic socket is located in the breaker box.
-the ports to the different rooms are also located in the box (there are 4 of them).
-in each room with a socket has only one ethernet port.
So now I was looking at the Ubiquiti EdgeRouter series and at the Unfi AP AC products the have and I am planing on ordering them. (1 Router and 2 AccessPoints)
At the moment I have 7 Machines that would need a wired connection.
So now my plan is to setup the whole network like this:
Fiber-Optic Socket -> Media Converter -> Router -> Switch (that connects the 4 Wall socket in the different rooms)
And then for the separate rooms:
I would need 4 more switches and two of them would be connected to the access points.
So now my question is:
What kind of router should I get and what kind of setup is the best for my breaker box?
-If I get the EdgeRouter Lite (2 Ports) I would have to connect it to a switch and then connect the ports to the separate plugs for the different rooms.
-If I get the EdgeRouter PoE I would have 4 Ports and could connect each plug for the different rooms directly to the the router.
-And then I was also playing with the Idea of getting the EdgeRouter Pro so I would not have to get a media converter and I also have some ports in case I would like to get a NAS or something down the road.
Is it better to connect the plugs for the different rooms directly to the router or is okay if I put a switch between router and the the 4 plugs?
Also since the EdgeRouter Pro does not have an integrated switch like the PoE I was wondering if I would still need a switch since I do not want to use it in bridge mode and I also do not really need 1 lan for each single room.
