homer2320776
I've run into a strange issue. I currently have a AC68U with 380.57 installed running an OpenVPN server. I also have it setup as a Dual Wan with Comcast on the WAN port and a local fiber provider on LAN Port 1.
Everything works as expected, except when I connect via OpenVPN to the server, I cannot access the LAN network except the router IP itself.
I've looked over everything I know to look at, all the correct options are checked but I still cannot pass traffic. I even tried to disable HW Acceleration and that ended up breaking the WIFI.
Here are the OpenVPN configs:
Server
# Automatically generated configuration
daemon
topology subnet
server 10.8.50.0 255.255.255.0
proto udp
rcvbuf 0
sndbuf 0
port 443
dev tun21
cipher AES-128-CBC
comp-lzo yes
keepalive 15 60
verb 3
push "route 192.168.50.0 255.255.255.0"
client-config-dir ccd
client-to-client
duplicate-cn
push "dhcp-option DNS 192.168.50.1"
ca ca.crt
dh dh.pem
cert server.crt
key server.key
status-version 2
status status 10
Client
client
dev tun
proto udp
remote ipaddress 443
float
cipher AES-128-CBC
comp-lzo yes
keepalive 15 60
ns-cert-type server
<ca>
</ca>
<cert>
</cert>
<key>
</key>
resolv-retry infinite
nobind
Any help would be appreciated!
Server
daemon
topology subnet
proto udp
rcvbuf 0
sndbuf 0
port 443
dev tun21
cipher AES-128-CBC
comp-lzo yes
keepalive 15 60
verb 3
client-to-client
duplicate-cn
ca ca.crt
dh dh.pem
cert server.crt
key server.key
status-version 2
status status 10
Client
client
dev tun
proto udp
float
cipher AES-128-CBC
comp-lzo yes
keepalive 15 60
ns-cert-type server
<ca>
</ca>
<cert>
</cert>
<key>
</key>
nobind
