Veepul
Hello
Just trying to figure out what am i doing wrong here
A) Router A
https://www.asus.com/Networking/DSLN10/
I use this asus adsl modem cum router to connect to internet.
B) Router B
http://www.tp-link.com/en/products/details/cat-9_TL-WR740N.html
-I connected this routers WAN port to one of the Lan ports of the asus router (PartB) above and hence get internet from A.
-This router then provides internet to one desktop via ethernet and various Wifi devices.
C) Router C
This router has been set up to repeat the wifi signals from RouterB. I enabled it from under WDS Bridging.
(Router B&C are same models from tplink)
My set up has never been stable especially with router C. I have to reconfigure it very frequently. There are always disconnections, ip conflicts etc.
Are there any extra settings or specific ones i need to do?
After lot of googling, I disabled the DHCP on Router C but then lost access to the routers settings page. The internet would work fine though.
My knowledge on ip, subnet, dhcp etc is very weak.
I am able to access Router A by 192.168.1.1 and Router B by 192.168.0.1
Please advise/suggest.
A) Router A
B) Router B
C) Router C
