Drinkerbelle
Okay, this is going to be quite long as I am a network noob; as such, I don’t know which items of information are important, and which may not be. Networking may not be in my wheelhouse (yet), but my senior grey matter is willing to learn... if someone is willing to be patient with me.
If I’m really not in the right place, perhaps someone could kindly direct me to a site where my long query would be better suited?
My BlueCave router has been losing the 2.4 GHz radio band fairly regularly since May (I bought it in January). It still maintains the 5 GHz band, but when my 2.4 band IOT devices disconnect… it is my first indication my 2.4 band has gone on hiatus.
When this happens, the client list in my router UI will not show anything for the 2.4 GHz band. (And if it matters, no, my SSID is NOT hidden.)
When turning on wifi for my phone, laptop, et al., my SSID for the 2.4 GHz band does not appear as a connection option.
My firmware version is the most current (3.0.0.4.384_45708).
I operate in wireless router mode, I've reset my control channel to 11 (from auto) to avoid any congestion from adjacent neighbors (as I live in a condo, and my adjacent neighbors appear to be on 1 or 6).
I disconnected my Blue Cave and connected my older RTN-66U Dark Knight router and had no difficulty with my 2.4 GHz band.
I performed a factory reset for my Blue Cave mid-May, renamed my SSID (differently for both bands), reconfigured from scratch, and tried connecting some devices to a dedicated guest network on the 2.4 band. I’ve changed out my modem to router Cat6 ethernet cable.
I have my router in the exact same location as my previous Dark Knight router, and it is in a location where I've never had any problem with RFI. (It sits atop a cabinet, though I've tried moving the location and orientation -- to the extent that I am able to from my modem -- and the same problem continues to exist.)
The configuration (and dictates) of my condo do not really allow much in the way of flexibility in the location of my modem or router, (or to hardwire). Living in a bit of a Mayberry-like town also limits reliable resources for technical assistance.
In any event, when the 2.4 band has worked, it’s been solid. But sometimes it just vanishes like cheap beer at a frat house.
I contacted ASUS support with this same information, and the only thing more difficult for me than trying to decipher what various networking parlance means on the fly, is trying to understand their requests from me (especially with some of the disparities in grammar).
I am running out of ideas about what is causing this problem, other than thinking there is a problem with the 2.4 radio band.
As far as I can discern, they are asking me to reset my router login credentials to default, and then save a system log and CFG file for their diagnosis. (Additionally, some supplemental information regarding my ISP, modem make/model, my own troubleshooting steps, etc.)
All of this is Greek to me, though they did provide enough cryptic advice that I can likely figure it out.
My question is really two-fold:
1) Once I capture the requested logs/files, can I immediately go back and change my router login?
2) Do these logs allow them access to any of my personal information like my WPA-PSK keys?
Also, is there some glaringly obvious oversight on my part that I am possibly missing?
If you’ve hung in here with this old gal to the bitter end, I sincerely both thank and applaud you for your patience. I would also like to say thank you in advance for any advice or insights you might offer.
