last night the Foxconn based Atom D2700 unit PSU died which disabled the router. I hooked Comcast directly to Acer C5 so it works for now but would like a replacement. My default route was to buy a decent Qotom from Amazon ( Celeron 3215U based unit with 4 intel NICs is ~150) throw in some RAM and HDD and put pfsense back on fanless hardware. However, I am also curious what are other choices before going the default route - basically in the market for UTM with primary features being firewall and routing. don't need wifi as it would be handled by another AP
Questions
1) anything good/bad to say about Mikrotik? I see a lot of cheap (~$60) units like these https://www.amazon.com/dp/B016E93IQS/?tag=snbforums-20 which in theory should do the routing trick. reading up on RouterOS now to understand difference between various "levels" of the license.
There are also slightly more expensive units like MikroTik Cloud Router Switch CRS109-8G-1S-2HnD-IN which is still cheaper than Qotom route
2) same for Sophos UTM
if you using any of the above, what are the carrying costs (annual licenses, etc).
Thank you
Questions
Thank you
