OOPS: child died Connection closed by remote host.
rdy2
I am running the Windows FTP client and getting error
ftp> cd /tmp/mnt/VERTEX2/scripts
500 OOPS: child died
A google search points to needing a tweak in vsftpv.conf
seccomp_sandbox=NO
I have not tried it yet. Has anyone run into this ?
The problem is that you are trying to change to a directory that you're not allowed to access (strictly speaking it's the path that's the problem).
EDIT: Try using this instead (assuming VERTEX2/scripts is the folder you have shared in the router's GUI):
cd /VERTEX2/scripts
cd /VERTEX2/scripts
You are right. I have two drives that to FTP appear as rooted on what is /tmp/mnt
(VERTEX60 is a leftover, nothing mounted there)
230 Login successful.
ftp> pwd
257 "/" is the current directory
ftp> ls
200 PORT command successful. Consider using PASV.
150 Here comes the directory listing.
/VERTEX1
/VERTEX2
/VERTEX60
226 Directory send OK.
ftp: 31 bytes received in 0.01Seconds 2.07Kbytes/sec.
M Disabling USB 3.0 on an AiMesh child ? Asuswrt-Merlin 6
