Oops my network is exposed to hackers
deepu007
Would appreciate any help on my home network. I have 2 routers (Asus RT-AC88u, Asus RT-N66u) and 1 switch (Netgear GS105Ev2). All of them are gigabit devices and Asus RT-N66u is my 3 year old router not connected to my network yet.
Attached is the picture of my home network. Current problem is that room1, room2 attached to my network don't have firewall unless the pc connected on these wires have soft firewall. I need to enhance my network so that I can introduce firewall. However I do not know the best way to achieve to it.
My plan is to replace the switch with router (which should have been how the network should be). I want to Asus RT-N66u as the first device on WAN (with wireless turned off - since my other router is covering all the house).
1.) Can we connect 2 routers to each other thru wired lines? Is there any setting I need to do,
2.) Do we need to use the switch any where in middle?
This is the first time I am doing this networking stuff. Thanks for helping in advance.
You can have the Asus RT-N66u (wifi turned off) in Router mode and the Asus RT-AC88u in AP mode, and connect this routers to each other thru wired line.
Why not skip the switch and use the ac88 as main router connected to the fiber modem?
If needed you can run a wire from the router to the switch to have additional ports
Verstuurd vanaf mijn A0001 met Tapatalk
Your diagram doesn't make sense. How are the PCs connecting to the switch getting internet? Does your fibre have multiple IP addresses?
The first thing after the fibre to ethernet conversion box should be a router. Everything else should be plugged in via that router.
