WetMacula
Merlin
Thanks for all you hard work. Using the latest FW, I moved the VPN server from a NAS to the N66U tonight. I can follow instructions and know just enough to be dangerous. Fortunately, everything is working. When connecting with clients I would like additional authentication with a login/pass prompt. Read the following howto and it appears a plugin is required.
http://openvpn.net/index.php/open-source/documentation/howto.html#auth
Is it possible to do this on the N66U?
Also, is it difficult to add an enable/disable/edit buttons to the port forwarding table? If not, that feature would be really convenient.
