Dismiss Notice
Welcome To SNBForums
OpenVPN and dnsmasq hostnames
Discussion in 'Asuswrt-Merlin' started by kaiguy, Feb 27, 2013.
  1. kaiguy
    kaiguy Regular Contributor
    Feb 27, 2013
    52
    Hey folks. Quick question:
    Does OpenVPN (on Merlin's build or otherwise) allow for host names to be resolved on the remote LAN? I have it up and running but no settings I change within the GUI seem to allow me to resolve those host names (which do resolve fine if connected locally). I would assume "Push LAN to client" and/or "Respond to DNS" and "Advertise DNS to clients" would be the ticket. Connecting via IP works great, but not so much by the hostname.
    Thanks for any input! Awesome firmware, Merlin!
  2. jochenthomas
    jochenthomas Occasional Visitor
    Dec 20, 2012
    27
    AFAIK, this is not possible, it's a typical openVPN issue :)
  3. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    18,654
    Canada
    Name resolution works fine for me through my OpenVPN tunnel, I just did it. Just make sure you do specify the remote network's local domain.
  4. kaiguy
    Feb 27, 2013
    52
    So if I specify my N66U's domain as "lan", I should be able to access my home network machines remotely via OpenVPN if I do hostname.lan ? Doesn't work for me for some reason.
  5. RMerlin
    Apr 14, 2012
    18,654
    Canada
    Make sure you have "Advertise DNS to clients" enabled on the OpenVPN server page, as well as Respond to DNS.
    Try an "nslookup hostname.lan" to ensure the issue is really with name resolution and not something else.
    I recommend using something like local.lan instead of just lan as your local domain.
Share This Page
