OpenVPN and IPV6
Vitaliy69
Hello!
I have the static native IPv6 network from my ISP. How do I allow clients to work through the IPv6 network?
I added to server user's settings:
proto udp6
server-ipv6 2002:d040:79a1:5::/64
push "route-ipv6 2000::/3"
push "dhcp-option DNS 2001:4860:4860::8888"
Then apply the firewall rules:
ip6tables -A INPUT -i tun21 -j ACCEPT
ip6tables -A FORWARD -i tun21 -j ACCEPT
ip6tables -I INPUT -p tcp --dport 1194 -j ACCEPT
ip6tables -I INPUT -p udp --dport 1194 -j ACCEPT
Add to the client settings tun-ipv6 option. The clients successfully got an IPv6 address, but IPv6 network is unreachable.
What am I doing wrong? Maybe some the firewall issue?
Thanks in advance!
I've read in some older threads that OpenVPN doesn't fully support IPV6, is that still the case for the latest builds?
I'm trying to connect to FrootVPN which uses IPV6 and so far I've been able to get it working on a desktop machine and a router that's running OpenWRT. Both of them I just used the ovpn file from Froot VPN and everything just worked, no problems getting it running.
I have an ASUS RT-N66U that's running 380.59 and when I try to setup the VPN client on it using the same file I just can't get it working. I can get the tunnel started and connected, but it's like nothing is getting routed over the tunnel to the VPN server. I'm wondering if it has to do with FrootVPN wanting to use IPV6.
I have the same problem
When trying to set a connection with the provided .ovpn file I always get the same error:
openvpn[886]: PUSH: Received control message: 'PUSH_REPLY,ifconfig-ipv6 2a00:1a28:1558:15::1011/64 2a00:1a28:1558:15::1,dhcp-option DNS 46.246.83.225,redirect-gateway def1,redirect-gateway ipv6,redirect-gateway def1,route-ipv6 2000::/3,block-outside-dns,tun-ipv6,route-gateway 46.246.83.225,topology subnet,ping 10,ping-restart 160,ifconfig 46.246.83.243 255.255.255.224'
openvpn[886]: Options error: unknown --redirect-gateway flag: ipv6
openvpn[886]: Options error: Unrecognized option or missing parameter(s) in [PUSH-OPTIONS]:7: block-outside-dns (2.3.12)
openvpn[886]: OPTIONS IMPORT: timers and/or timeouts modified
openvpn[886]: OPTIONS IMPORT: --ifconfig/up options modified
openvpn[886]: OPTIONS IMPORT: route options modified
openvpn[886]: OPTIONS IMPORT: route-related options modified
openvpn[886]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
openvpn[886]: TUN/TAP device tun11 opened
openvpn[886]: TUN/TAP TX queue length set to 100
openvpn[886]: do_ifconfig, tt->ipv6=1, tt->did_ifconfig_ipv6_setup=1
openvpn[886]: /usr/sbin/ip link set dev tun11 up mtu 1500
openvpn[886]: /usr/sbin/ip addr add dev tun11 46.246.83.243/27 broadcast 46.246.83.255
openvpn[886]: /usr/sbin/ip -6 addr add 2a00:1a28:1558:15::1011/64 dev tun11
openvpn[886]: Linux ip -6 addr add failed: external program exited with error status: 2
openvpn[886]: Exiting due to fatal error
Don't know How to solve it.
Bye.
Hello!
proto udp6
Thanks in advance!
Hi there -
Use -I instead of -A to place the rules in front instead of at the back - somehow that made a difference some of the other rules in the list must be interfering with it. Worked for me after several hours of fiddling! :)
