darkpollo
I have an OpenVPN server and I would like to connect using the OpenVPN client on the Asus.
I import the ovpn file but it gives me an error:
Apr 30 11:40:13 openvpn[3022]: neither stdin nor stderr are a tty device, can't ask for Private Key password. If you used --daemon, you need to use --askpass to make passphrase-protected keys work, and you can not use --auth-nocache.
Apr 30 11:40:13 openvpn[3022]: Exiting due to fatal error
It seems that the key cannot be password protected. Is there any way to make this work on the client or do I need to create a key without the pass to use on the router?
