OpenVPN recursive routing detecting
Olivier L
Hello
My log is populated with a lot of
ovpn-client4[23137]: Recursive routing detected, drop tun packet to [AF_INET]IPXXXXXX
I do no understand why.
I have to other clients running well with no such message.
What shoud I check ?
Thnaks
If you run multiple clients, then you must have a routing conflict. You need to make sure that all clients are using a different subnet.
Who's the OpenVPN provider for the one having the problem (I'm asking because I have seen this problem w/ PureVPN in the past)?
Does the problem go away when that's the only active OpenVPN client?
