Dismiss Notice
Welcome To SNBForums
OpenVPN & Two VPN Tabs
Discussion in 'Asuswrt-Merlin' started by HawkInOz, Jan 29, 2013.
  1. HawkInOz
    HawkInOz Regular Contributor
    Jan 14, 2012
    77
    I have OpenVPN working perfectly on my RT-N66U with Merlin's .23b firmware. I would like to disable any unnecessary items on the VPN Server and VPN Details tabs, if not required for OpenVPN to be fully functional.
    Specifically, can I set "Enable PPTP Server" to "No" on the VPN Server tab, and can I uncheck any or all of the boxes next to "MPPE Encryption" on the VPN Details tab?
    Thank you!
  2. RMerlin
    RMerlin Part of the Furniture
    Apr 14, 2012
    18,658
    Canada
    Turning off the option of a disabled VPN service will not do anything at all, beside write a "0" instead of a "1" into nvram. There is no point in disabling every PPTP options if PPTP itself is kept disabled.
  3. HawkInOz
    Jan 14, 2012
    77
    So, are you saying to go ahead and set "Enable PPTP Server" to "No" on the VPN Server tab - and that's all I need to do? It would seem that I would need to at least do that to disable the PPTP Server from running in addition to the OpenVPN Server, as indicated on the VPN Status tab. And to clarify, this will have absolutely no effect on the OpenVPN server?
    Thanks.
Share This Page
