Running OpenVPN server on RT-AC5300 with latest merlin image.
I can connect and access the LAN on the AC-5300 fine, I have another LAN segment on a switch connected to the AC-5300 and have static route built to this LAN. I have a default route back from this LAN on the switch to the AC-5300 and can ping this LAN from the tools section on the router.
I have added a "push" for this LAN to the server config and my client receives and makes the correct entry in the route table for this IP network.
When I try to reach this IP network from the client, I can see the packet being dropped when I enable FW logging on the router side.
What entries am I missing on the server / client side to make this work? I looked at IP tables on the router and do not see what entries are getting created to make the 10.8.0.0 for the VPN client and LAN that is local to the router? What entry do I need to make so the incoming packet does not get dropped by FW? Just trying to figure out the "magic" done behind the scenes for the VPN client and the local LAN.
Thanks,
Jeff
Thanks,
Jeff
