Permission denied on several scripts
kha
Hello,
This morning I logged onto my RT-N66U with latest Merlin firm. (Firmware Version:3.0.0.4.270.24 (Merlin build)) to check crontabs.
I ran:
cru l
and got:
[kha@RT-N66U root]$ cru l
/usr/sbin/cru: line 4: nvram: Permission denied
Line 4 is:
F="$D/`nvram get http_username`"
If i run it it works:
[kha@RT-N66U root]$ nvram get http_username
kha
It's like the interpreter does not work... Yetserday I installed through ipkg packages bash, bash-completion and core-utils... I am wondering what can cause this issue: when runnign scripts, it's like the interpreter does not have any right to run binaries...
i also tried to run
ipkg update
but got:
[kha@RT-N66U root]$ ipkg update
Downloading http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz
sh: wget: Permission denied
Downloading http://dlcdnet.asus.com/pub/ASUS/wireless/ASUSWRT/Packages.gz
An error ocurred, return value: 2.
Collected errors:
ipkg_download: ERROR: Command failed with return value 127: `wget    -q -P /opt/ipkg-CQBWnZ http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz'
ipkg_download: ERROR: Command failed with return value 127: `wget    -q -P /opt/ipkg-CQBWnZ http://dlcdnet.asus.com/pub/ASUS/wireless/ASUSWRT/Packages.gz'
I removed bash-completion and bash package and cru now works.
But ipkg update till cannot download some packages:
kha@RT-N66U:/tmp/home/root# ipkg update
Inflating http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz
Updated list of available packages in /opt/lib/ipkg/lists/optware.oleg
wget: server returned error: HTTP/1.1 404 Not Found
An error ocurred, return value: 1.
Collected errors:
ipkg_download: ERROR: Command failed with return value 1: `wget    -q -P /opt/ipkg-YTYTJ0 http://dlcdnet.asus.com/pub/ASUS/wireless/ASUSWRT/Packages.gz'
Does someone knows why bash did not work for me ? Also is there another URL I can set to make ipkg update work ?
That error message is normal. Asus doesn't have a fully working optware repo, so there's no Packages.gz file.
And for the bash install not working properly, do you have an idea ?
No idea, you only posted logs of the ipkg update, not of the bash install attempt.
After installing bash, the prompt changed from # to $, indicating a loss of root privilege.
It's a optware-related issue, because a long time ago when I use TomatoUSB I had the same problem, and I solved it by editng some file like /opt/etc/profile, but I don't remember exactly nor how, nether can I google anything out today. Waiting for a solution.
Here is how to reproduce the issue:
1. Make a clean install of optware. Can be done by installing Asus DownloadMaster and then uninstall it.
2. telnet/ssh to router, you will be prompted with a # and no problem.
3. ipkg install bash, then exit the telnet/ssh session.
4. re-telnet/ssh, you'll be prompted with a $, root privilege lost.
5. umount the optware device. re-telnet/ssh, you gain root again, no problem.
6. telnet/ssh after optware device mounted, you lost root.
Appreciate a solution
I got it. Edit /opt/etc/profile
change this line
LD_LIBRARY_PATH=/opt/lib:${LD_LIBRARY_PATH}
to
LD_LIBRARY_PATH=/lib:/opt/lib:${LD_LIBRARY_PATH}
Problem solved. So it's a lib path search order issue.
BTW, the PS1 should end with \$, instead of $, otherwise always shows $.
