Phoenix, Smartreader for oscam are mounted lika a modem 3G/4G
MiCk
At the beginning, I would like to say hello.
Merlin Software I use a few days. Previously I worked on Tomato by Shibby almost an year.
So I have a problem as the topic. I would like to run OSCAM server.
Now on Merlin I have problem with the mount reader: phoenix or smargo.
They are recognized as 3G/4G modem and oscam does not start.
usbcore: registered new interface driver usbserial
drivers/usb/serial/usb-serial.c: USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
drivers/usb/serial/usb-serial.c: USB Serial Driver core
drivers/usb/serial/usb-serial.c: USB Serial support registered for GSM modem (1-port)
option 1-1.1:1.0: GSM modem (1-port) converter detected
usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
usbcore: registered new interface driver option
drivers/usb/serial/option.c: USB Driver for GSM modems: v0.7.2
I doesn't have any idea why it happends ?
I tried manualy add records to run modules usbserial and ftdi_sio but always after restart router readers are mounted like modem.
Maybe some one have some idea how to solve it?
Does it not work to tell oscam to use /dev/ttyUSB0 as the device??
Genereally GSM modems are treated just like any serial device, so that the log says it's a GSM modem shouldn't matter.
An option.ko got dynamic slot which Asus uses in following hack: every device with serial endpoint is to be handled by option.ko. Unload option.ko and load appropriate modules.
I've got the same trouble when tried to use USB-LAN dongle. Now my RT-N66U got 5 LAN ports:)
Thanks guys for support.
So I wrote in services-start:
modprobe -r -v option.ko
insmod usbserial
insmod ftdi_sio
and oscam works :)
ryzhov_al what do you think, is it optimal or can I do this records better ?
