PIA (OPENVPN) on a RT-AC3200 and running 378.53 tls issues
San
Hi as you can see I am new here hope you can help me , I am trying to setup openvpn via Private Internet Access but I have tls errord and the cert is there any help really apreciated
from the log
rc_service: httpd 546:notify_rc start_vpnclient1
kernel: tun: Universal TUN/TAP device driver, 1.6
kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
openvpn[8367]: DEPRECATED OPTION: --tls-remote, please update your configuration
openvpn[8367]: OpenVPN 2.3.6 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Apr 28 2015
openvpn[8367]: library versions: OpenSSL 1.0.2a 19 Mar 2015, LZO 2.09
openvpn[8367]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
openvpn[8368]: UDPv4 link local: [undef]
openvpn[8368]: UDPv4 link remote: [AF_INET]50.97.82.42:1194
openvpn[8368]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
openvpn[8368]: TLS_ERROR: BIO read tls_read_plaintext error: error:14090086:SSL routines:ssl3_get_server_certificate:certificate verify failed
openvpn[8368]: TLS Error: TLS object -> incoming plaintext read error
openvpn[8368]: TLS Error: TLS handshake failed
openvpn[8368]: SIGUSR1[soft,tls-error] received, process restarting
openvpn[8368]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
openvpn[8368]: UDPv4 link remote: [AF_INET]173.192.105.196:1194
openvpn[8368]: UDPv4 link remote: [AF_INET]184.173.77.50:1194
You didn't specify a cipher. Check with PIA what cipher you should use there. OpenVPN defaults to Blowfish, but many tunnel providers use AES-128-CBC or AES-256-CBC.
