Hi all,
I am having an odd problem with my ASUS RT-AC66U B1 running Merlin latest version.
This issue only started today with no known changes made. I did upgrade to the latest version of Merlin but that was about 2 weeks ago.
The issue is that my son has a PlayStation 5 and as of this morning can no longer connect to the PlayStation network. If I try log into PlayStation on the computer, the page shows "not acceptable" and also doesn't load. Same lack of access on the PlayStation app of my cell phone on wireless.
I would put this down to a PSN Network issue except I think my troubleshooting shows otherwise:
1) If I take the ASUS out of the mix, and plug the PlayStation directly into the ISP modem - it works fine. Same with connecting to LTE on my phone, works fine.
2) If I activate my VPN at the modem level, all access works - this is a work around but I prefer not to have to use the VPN all the time.
I have reset the ASUS to defaults as well as flashed to stock firmware (latest version) with no change.
I can't see how PlayStation would be for some reason blocking my IP because of 1) above.
I have checked PlayStation network status and other forums and seems it's not a widespread issue.
I was going to check with my ISP but based on troubleshooting they will just point to my ASUS.
Does anyone have any ideas??
Thanks for any help!
