In the article here:
http://www.smallnetbuilder.com/wire...onvert-a-wireless-router-into-an-access-point
It shows an image of the AP with a big box that says "DO NOT connect here" pointed at the WAN port.
I have an older NetGear WNR2000 which I was thinking of using as an AP, but in the manual it specifically says to connect the WAN port of the AP to the router's LAN port (see attachment). I would imagine I should follow the router's manual, but I'm curious why there's a difference - my guess is because the WNR2000 has a specific "AP mode". Are the instructions in the SNB article for routers which do not have a specific AP mode?
Thanks!
Thanks!
