Eyely Kaynal
Hello everybody.
I've just purchased the RT-N66U and flashed Merlin's 378.55 firmware.
I'm trying to forward ports but I'm having no luck. I'm no expert, but I've managed this successfully with no issues on my last 5 routers.
I'm using port 13338 as a test. When forwarded manually, it is closed. However, when the port is opened via a program using UPnP, it works fine.
I will attach a copy of an 'iptables --table nat --list -v -n' printout for both instances below. Instance 1 is with UPnP enabled. Instance 2 is without. Could anyone please help me with this?
Also, I notice at the top of my iptables that there are two private IPs (10.x.y.z and 169.x.y.x). When I type these into my browser, my router's config page appears. I've never noticed this before, could anyone a little wiser than myself please advise me on what/why this is?
I appreciate any help anyone can provide and I apologise if I've overlooked something small and/or done something wrong.
Regards,
Colin
1-------(port open)-------iptables --table nat --list -v -n
Chain PREROUTING (policy ACCEPT 707 packets, 56744 bytes)
pkts bytes target prot opt in out source destination
151 9739 VSERVER all -- * * 0.0.0.0/0 10.65.154.214
0 0 VSERVER all -- * * 0.0.0.0/0 169.254.58.197
Chain POSTROUTING (policy ACCEPT 24 packets, 6058 bytes)
525 43430 MASQUERADE all -- * ppp0 !10.65.154.214 0.0.0.0/0
0 0 MASQUERADE all -- * vlan50 !169.254.58.197 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 11 packets, 4147 bytes)
Chain DNSFILTER (0 references)
Chain LOCALSRV (0 references)
Chain PCREDIRECT (0 references)
Chain VSERVER (2 references)
0 0 DNAT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:8080 to:192.168.5.1:80
0 0 DNAT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpts:27030:27039 to:192.168.5.82
0 0 DNAT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpts:27000:27015 to:192.168.5.82
0 0 DNAT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:1200 to:192.168.5.82
0 0 DNAT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:13338 to:192.168.5.82:13338
13 1911 DNAT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:13338 to:192.168.5.82:13338
138 7828 VUPNP all -- * * 0.0.0.0/0 0.0.0.0/0
Chain VUPNP (1 references)
0 0 DNAT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:13338 to:192.168.5.82:13338
2-------(port closed)-------iptables --table nat --list -v -n
Chain PREROUTING (policy ACCEPT 735 packets, 58851 bytes)
169 10924 VSERVER all -- * * 0.0.0.0/0 10.65.154.214
Chain POSTROUTING (policy ACCEPT 28 packets, 6888 bytes)
534 44145 MASQUERADE all -- * ppp0 !10.65.154.214 0.0.0.0/0
Chain OUTPUT (policy ACCEPT 12 packets, 4572 bytes)
16 2316 DNAT udp -- * * 0.0.0.0/0 0.0.0.0/0 udp dpt:13338 to:192.168.5.82:13338
153 8608 VUPNP all -- * * 0.0.0.0/0 0.0.0.0/0
Regards,
Colin
