vibroverbus
Situation:
- HP printer w static IP. Minimal network config in device, ie no IPv6, all whacky HP and non essential services stuff turned off except AirPrint. Wired connection direct to router.
- PC, Mac, iOS clients all properly config'd to point at printers static IP
- Start all devices, works perfectly. Print from PC, Mac, iOS clients. Zero issues.
- AC3200 has nightly reboot scheduled. Works fine for all devices and zero WAN or wifi access issues before or after reboot.
Problem:
- After reboot no printing to wired printer works from any device
- Printer internal web server works fine - easily accessed from. 192.168.etc. can navigate printer info and config pages etc. but still cant send print jobs.
- Clients still seem to see printer - no error in connection - but jobs never seem to start, sit in hung in queue and printer doesnt show jobs coming through.
- Forceably reboot printer - all is well.
I have seen this weird problem before occaisionally with other printer makes/models on DD-WRT routers but not consistently and never figured out a cause or solution. Its like after the reboot either some packets arent getting to the printer, or, its print service demon hangs after the ethernet connection cycles.
Suggestions or BTDT?
Problem:
