Problems with RT-AC87U loosing WAN
miniterror
Hello all,
I have a RT-AC87U running and verry often i loose internet connection.
When looking in the log i see alot of errors and emergency syncs.
I called the provider of the connection and they say there arent any problems with the connection itself and the Asus is the problem.
I hope some one here can point me in the direction what is causing the problem and how to fix the problems i have recently.
The Asus is running firmware 3.0.0.4.380_3459.
The asus whas running auto restart every day at 02:00, but i turned that off today just in case that is causing the problems.
I posted the log from the Asus, post number 2 is the oldest part of the log, if you post all the lines in one document itll be how it looks in the asus. I did it like this cause i got a error of 10000chars when posting in bigger parts.
post2
post3
post4
Aug  1 02:00:10 syslogd started: BusyBox v1.17.4
Aug  1 02:00:10 kernel: klogd started: BusyBox v1.17.4 (2016-05-27 10:04:21 CST)
Aug  1 02:00:10 kernel: Linux version 2.6.36.4brcmarm (root@asus) (gcc version 4.5.3 (Buildroot 2012.02) ) #1 SMP PREEMPT Fri May 27 10:13:13 CST 2016
Aug  1 02:00:10 kernel: CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7f
Aug  1 02:00:10 kernel: CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Aug  1 02:00:10 kernel: Machine: Northstar Prototype
Aug  1 02:00:10 kernel: Ignoring unrecognised tag 0x00000000
Aug  1 02:00:10 kernel: Memory policy: ECC disabled, Data cache writealloc
Aug  1 02:00:10 kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 60416
Aug  1 02:00:10 kernel: Kernel command line: root=/dev/mtdblock2 console=ttyS0,115200 init=/sbin/preinit earlyprintk debug
Aug  1 02:00:10 kernel: Memory: 255504k/255504k available, 6640k reserved, 0K highmem
Aug  1 02:00:10 kernel: Virtual kernel memory layout:
Aug  1 02:00:10 kernel:     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
Aug  1 02:00:10 kernel:     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
Aug  1 02:00:10 kernel:     DMA     : 0xf7e00000 - 0xffe00000   ( 128 MB)
Aug  1 02:00:10 kernel:     vmalloc : 0xd0800000 - 0xf0000000   ( 504 MB)
Aug  1 02:00:10 kernel:     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
Aug  1 02:00:10 kernel:     modules : 0xbf000000 - 0xc0000000   (  16 MB)
Aug  1 02:00:10 kernel:       .init : 0xc0008000 - 0xc003d000   ( 212 kB)
Aug  1 02:00:10 kernel:       .text : 0xc003d000 - 0xc03a5000   (3488 kB)
Aug  1 02:00:10 kernel:       .data : 0xc03bc000 - 0xc03df120   ( 141 kB)
Aug  1 02:00:10 kernel: External imprecise Data abort at addr=0x0, fsr=0x1c06 ignored.
Aug  1 02:00:10 kernel: Mount-cache hash table entries: 512
Aug  1 02:00:10 kernel: CPU1: Booted secondary processor
Aug  1 02:00:10 kernel: Found a AMD NAND flash:
Aug  1 02:00:10 kernel: Total size:  128MB
Aug  1 02:00:10 kernel: Block size:  128KB
Aug  1 02:00:10 kernel: Page Size:   2048B
Aug  1 02:00:10 kernel: OOB Size:    64B
Aug  1 02:00:10 kernel: Sector size: 512B
Aug  1 02:00:10 kernel: Spare size:  16B
Aug  1 02:00:10 kernel: ECC level:   8 (8-bit)
Aug  1 02:00:10 kernel: Device ID: 0x 1 0xf1 0x80 0x1d 0x 1 0xf1
Aug  1 02:00:10 kernel: bio: create slab <bio-0> at 0
Aug  1 02:00:10 kernel: PCI: no core
Aug  1 02:00:10 kernel: PCI: Fixing up bus 0
Aug  1 02:00:10 kernel: PCI: Fixing up bus 1
Aug  1 02:00:11 kernel: VFS: Disk quotas dquot_6.5.2
Aug  1 02:00:11 kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Aug  1 02:00:11 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:11 kernel: pflash: found no supported devices
Aug  1 02:00:11 kernel: bcmsflash: found no supported devices
Aug  1 02:00:11 kernel: Boot partition size = 524288(0x80000)
Aug  1 02:00:11 kernel: lookup_nflash_rootfs_offset: offset = 0x200000
Aug  1 02:00:11 kernel: nflash: squash filesystem with lzma found at block 28
Aug  1 02:00:11 kernel: Creating 4 MTD partitions on "nflash":
Aug  1 02:00:11 kernel: 0x000000000000-0x000000080000 : "boot"
Aug  1 02:00:11 kernel: 0x000000080000-0x000000200000 : "nvram"
Aug  1 02:00:11 kernel: 0x000000200000-0x000004000000 : "linux"
Aug  1 02:00:11 kernel: 0x00000039ac80-0x000004000000 : "rootfs"
Aug  1 02:00:11 qcsapi: write qcsapi conf ok
Aug  1 02:00:11 kernel: Registering the dns_resolver key type
Aug  1 02:00:11 kernel: Spare area=64 eccbytes 56, ecc bytes located at:
Aug  1 02:00:11 kernel:  2 3 4 5 6 7 8 9 10 11 12 13 14 15 18 19 20 21 22 23 24 25 26 27 28 29 30 31 34 35 36 37 38 39 40 41 42 43 44 45 46 47 50 51 52 53 54 55 56 57 58 59 60 61 62 63
Aug  1 02:00:11 kernel: Available 7 bytes at (off,len):
Aug  1 02:00:11 kernel: (1,1) (16,2) (32,2) (48,2) (0,0) (0,0) (0,0) (0,0)
Aug  1 02:00:11 kernel: Options: NO_AUTOINCR,NO_READRDY,BBT_SCAN2NDPAGE,
Aug  1 02:00:11 kernel: Creating 2 MTD partitions on "brcmnand":
Aug  1 02:00:11 kernel: 0x000004000000-0x000007ec0000 : "brcmnand"
Aug  1 02:00:11 kernel: 0x000007ec0000-0x000008000000 : "asus"
Aug  1 02:00:11 kernel: VFS: Mounted root (squashfs filesystem) readonly on device 31:3.
Aug  1 02:00:11 kernel: ctf: module license 'Proprietary' taints kernel.
Aug  1 02:00:11 kernel: Disabling lock debugging due to kernel taint
Aug  1 02:00:11 kernel: et_module_init: passivemode set to 0x0
Aug  1 02:00:11 kernel: et_module_init: txworkq set to 0x1
Aug  1 02:00:11 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug  1 02:00:11 kernel: =================
Aug  1 02:00:11 kernel: robo chk regs:
Aug  1 02:00:11 kernel: ===================
Aug  1 02:00:11 kernel: (0x00,0x5d)Port 5 States Override: 0xfb
Aug  1 02:00:11 kernel: (0x00,0x5f)Port 7 States Override: 0xfb
Aug  1 02:00:11 kernel: (0x00,0x0e)Port 8 States Override: 0x0a
Aug  1 02:00:11 kernel: (0x00,0x08)Port 8 IMP Control Register: 0x00
Aug  1 02:00:11 kernel: (0x02,0x00) Global Management Config: 0x00
Aug  1 02:00:11 kernel: (0x02,0x00) 802.1Q VLAN Control 5: 0x00
Aug  1 02:00:11 kernel: (0x02,0x03) BRCM HDR Control Register: 0x00
Aug  1 02:00:11 kernel: (0x00,0x0b) Switch Mode Register: 0x06
Aug  1 02:00:11 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.37.14.126 (r561982)
Aug  1 02:00:11 kernel: wl_module_init: passivemode set to 0x0
Aug  1 02:00:11 kernel: wl_module_init: igs set to 0x0
Aug  1 02:00:11 kernel: wl_module_init: txworkq set to 0x1
Aug  1 02:00:11 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.126 (r561982)
Aug  1 02:00:11 kernel: _ Reboot message ... _______________________________________________________
Aug  1 02:00:11 kernel: <4>Emergency Sync complete
Aug  1 02:00:11 kernel: <4>gro disabled
Aug  1 02:00:11 kernel: <��U�tempt to kill tasklet from interrupt
Aug  1 02:00:11 kernel: <6>device eth0 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 1(vlan1) entering forwarding state
Aug  1 02:00:11 kernel: <6>device eth0 entered promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: topology change detected, propagating
Aug  1 02:00:11 kernel: <6>br0: port 2(eth1) entering forwarding state
Aug  1 02:00:11 kernel: <6>device vlan1 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 1(vlan1) entering disabled state
Aug  1 02:00:11 kernel: <6>device eth1 left promiscuous mode
Aug  1 02:00:11 kernel: <6>br0: port 2(eth1) entering disabled state
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_mbim
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ncm
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver qmi_wwan
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_wdm
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver rndis_host
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver cdc_ether
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver asix
Aug  1 02:00:11 kernel: <6>usbcore: deregistering interface driver usblp
Aug  1 02:00:11 kernel: <6>xhci_hcd 0000:00:0c.0: remove, state 1
Aug  1 02:00:11 kernel: <6>usb usb1: USB disconnect, address 1
Aug  1 02:00:11 kernel: <6>xhci_hcd 0000:00:0c.0: USB bus 1 deregistered
Aug  1 02:00:11 kernel: <4>Attempt to kill tasklet from interrupt
Aug  1 02:00:11 kernel: ____________________________________________________________________________
Aug  1 02:00:24 RT-AC87U: start httpd
Aug  1 02:00:24 disk monitor: be idle
Aug  1 02:00:24 wan: [wan0_hwaddr] == [xx;xx;xx;xx;xx;xx]
Aug  1 02:00:24 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Aug  1 02:00:24 hour monitor: daemon is starting
Aug  1 02:00:24 hour monitor: daemon terminates
Aug  1 02:00:25 miniupnpd[473]: version 1.9 started
Aug  1 02:00:25 miniupnpd[473]: HTTP listening on port 44913
Aug  1 02:00:25 miniupnpd[473]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:25 syslog: Generating SSL certificate...
Aug  1 02:00:25 kernel: nf_conntrack_rtsp v0.6.21 loading
Aug  1 02:00:25 kernel: nf_nat_rtsp v0.6.21 loading
Aug  1 02:00:25 wan: finish adding multi routes
Aug  1 02:00:25 miniupnpd[473]: shutting down MiniUPnPd
Aug  1 02:00:26 miniupnpd[531]: version 1.9 started
Aug  1 02:00:26 miniupnpd[531]: HTTP listening on port 36000
Aug  1 02:00:26 miniupnpd[531]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:26 ntp: start NTP update
Jul 10 02:02:36 rc_service: ntp 532:notify_rc restart_upnp
Jul 10 02:02:36 WAN Connection: WAN was restored.
Jul 10 02:02:36 kernel: SCSI subsystem initialized
Jul 10 02:02:38 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jul 10 02:02:38 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jul 10 02:02:38 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Jul 10 02:02:38 miniupnpd[531]: shutting down MiniUPnPd
Jul 10 02:02:38 rc_service: ntp 532:notify_rc restart_diskmon
Jul 10 02:02:38 disk_monitor: Finish
Jul 10 02:02:39 miniupnpd[656]: version 1.9 started
Jul 10 02:02:39 miniupnpd[656]: HTTP listening on port 46690
Jul 10 02:02:39 miniupnpd[656]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 10 02:02:40 disk monitor: be idle
Jul 10 02:03:04 qtn: bootcfg.tgz exists
Jul 10 02:03:11 crond[433]: time disparity of 495362 minutes detected
Jul 10 10:11:50 DualWAN: skip single wan wan_led_control - WANRED off
Jul 10 10:11:50 stop_nat_rules: apply the redirect_rules!
Jul 10 10:16:15 WAN Connection: Ethernet link down
Jul 10 10:16:15 WAN Connection: Ethernet link down.
Aug  1 02:00:10 kernel: * Invalid signature of oopsbuf: 8D-EF-FF-E9-2F-FE-65-5B (len 770007525)
Aug  1 02:00:10 stop_nat_rules: apply the redirect_rules!
Aug  1 02:00:11 kernel: jffs2_scan_eraseblock(): Node at 0x02efd7f8 {0x1985, 0xe002, 0x000001a9) has invalid CRC 0xe0021985 (calculated 0xbd2008cf)
Aug  1 02:00:11 kernel: jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x02efd7fc: 0x01a9 instead
Aug  1 02:00:23 RT-AC87U: start httpd
Aug  1 02:00:24 wan: [wan0_hwaddr] == [F8:32:E4:79:01:48]
Aug  1 02:00:24 syslog: Generating SSL certificate...
Aug  1 02:00:24 miniupnpd[472]: version 1.9 started
Aug  1 02:00:24 miniupnpd[472]: HTTP listening on port 39110
Aug  1 02:00:24 miniupnpd[472]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:25 miniupnpd[472]: shutting down MiniUPnPd
Aug  1 02:00:25 miniupnpd[531]: version 1.9 started
Aug  1 02:00:25 miniupnpd[531]: HTTP listening on port 42782
Aug  1 02:00:25 miniupnpd[531]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:25 ntp: start NTP update
Jul 10 21:34:29 rc_service: ntp 532:notify_rc restart_upnp
Jul 10 21:34:29 kernel: SCSI subsystem initialized
Jul 10 21:34:29 WAN Connection: WAN was restored.
Jul 10 21:34:30 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jul 10 21:34:30 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jul 10 21:34:30 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Jul 10 21:34:31 miniupnpd[531]: shutting down MiniUPnPd
Jul 10 21:34:31 miniupnpd[656]: version 1.9 started
Jul 10 21:34:31 miniupnpd[656]: HTTP listening on port 53734
Jul 10 21:34:31 miniupnpd[656]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 10 21:34:31 rc_service: ntp 532:notify_rc restart_diskmon
Jul 10 21:34:31 disk_monitor: Finish
Jul 10 21:34:34 disk monitor: be idle
Jul 10 21:34:57 qtn: bootcfg.tgz exists
Jul 10 21:35:05 crond[433]: time disparity of 496534 minutes detected
Jul 10 22:00:34 disk_monitor: Got SIGALRM...
Jul 10 23:00:34 disk_monitor: Got SIGALRM...
Jul 11 02:00:28 kernel: Emergency Sync complete
Aug  1 02:00:25 miniupnpd[476]: version 1.9 started
Aug  1 02:00:25 miniupnpd[476]: HTTP listening on port 56885
Aug  1 02:00:25 miniupnpd[476]: Listening for NAT-PMP/PCP traffic on port 5351
Aug  1 02:00:26 wan: finish adding multi routes
Aug  1 02:00:26 miniupnpd[476]: shutting down MiniUPnPd
Aug  1 02:00:26 miniupnpd[531]: HTTP listening on port 58340
Jul 11 02:02:41 rc_service: ntp 532:notify_rc restart_upnp
Jul 11 02:02:41 kernel: SCSI subsystem initialized
Jul 11 02:02:42 kernel: xhci_hcd 0000:00:0c.0: Failed to enable MSI-X
Jul 11 02:02:42 kernel: xhci_hcd 0000:00:0c.0: failed to allocate MSI entry
Jul 11 02:02:42 kernel: usb usb1: No SuperSpeed endpoint companion for config 1  interface 0 altsetting 0 ep 129: using minimum values
Jul 11 02:02:43 miniupnpd[531]: shutting down MiniUPnPd
Jul 11 02:02:43 rc_service: ntp 532:notify_rc restart_diskmon
Jul 11 02:02:43 disk_monitor: Finish
Jul 11 02:02:43 miniupnpd[655]: version 1.9 started
Jul 11 02:02:43 miniupnpd[655]: HTTP listening on port 53797
Jul 11 02:02:43 miniupnpd[655]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 11 02:02:45 disk monitor: be idle
Jul 11 02:02:45 WAN Connection: WAN was restored.
Jul 11 02:03:09 qtn: bootcfg.tgz exists
Jul 11 02:03:16 crond[433]: time disparity of 496802 minutes detected
Jul 11 11:25:06 syslogd started: BusyBox v1.17.4
Jul 11 11:25:06 kernel: klogd started: BusyBox v1.17.4 (2016-05-27 10:04:21 CST)
Jul 11 11:25:06 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Jul 11 11:25:07 miniupnpd[1073]: version 1.9 started
Jul 11 11:25:07 miniupnpd[1073]: HTTP listening on port 45158
Jul 11 11:25:07 miniupnpd[1073]: Listening for NAT-PMP/PCP traffic on port 5351
Jul 11 11:25:08 hour monitor: daemon is starting
Jul 11 11:25:08 hour monitor: daemon terminates
