QNAP - QTS 4.2 Released - Intel/ARM
sfx2000
Part of the Furniture
QTS4.2.0 Build 0925 (Official release for the specific models)
( 2015/10/07 )
[Applicable Models]
SS-439 Pro, SS-839 Pro, TS-110, TS-112/TS-112P, TS-119/TS-119P+/TS-119P II, TS-120, TS-121, TS-1269U-RP, TS-210, TS-212/TS-212-E/TS-212P, TS-219/TS-219P/TS-219P+/TS-219P II, TS-220, TS-221, TS-239 Pro, TS-239H, TS-239 Pro II, TS-239 Pro II+, TS-259Pro/TS-259 Pro+, TS-269 Pro/TS-269L, TS-410, TS-410U, TS-412, TS-412U, TS-419P/TS-419P+/TS-419P II, TS-419U/TS-419U+/TS-419U II, TS-420, TS-420U, TS-421, TS-421U, TS-439 Pro, TS-439 Pro II, TS-439 Pro II+, TS-439U RP/SP, TS-459 Pro/TS-459 Pro+/TS-459 Pro II, TS-459U-RP+/SP+/TS-459U-RP/SP , TS-469 Pro/TS-469L, TS-469U-RP/SP, TS-509 Pro, TS-559 Pro/TS-559 Pro+/TS-559 Pro II, TS-569 Pro/TS-569L, TS-639 Pro, TS-659 Pro/TS-659Pro+/TS-659Pro II, TS-669 Pro/TS-669L, TS-809 Pro, TS-809U-RP, TS-859 Pro/TS-859 Pro+, TS-859U-RP/TS-859U-RP+, TS-869 Pro/TS-869L, TS-869U-RP, TS-269H, HS-210, IS-400 Pro, TS-251/TS-451/TS-651/TS-851, TS-253/TS-453/TS-653/TS-853, SS-453 Pro/SS-853 Pro, HS-251, TS-131/TS-231/TS-431, TS-231+/TS-431+, TS-453U/TS-453U-RP/TS-853U/TS-853U-RP/TS-1253U/TS-1253U-RP, TS-451U, TS-431U, TS-563
QTS4.2.0 Build 0925
[Bug Fixes]
This release has corrected the following issues:
- When playing photos as a slideshow on a DLNA TV, Photo Station 5 will get stuck on a single photo.
- Qvideo for iOS fails to load .srt files.
- Qvideo for Android fails to load .srt files.
- Video Station fails to update movie information.
- The Episode Filter in Download Station cannot recognize Italian characters.
- The system incorrectly recognizes Traditional Chinese filenames if they are uploaded to the NAS (mapped as a FTP drive) using Windows File Explorer.
- The system fails to remove the .dsdownload filename extension once files have finished downloading.
- Photo Station fails to load Pixlr Editor.
- The system fails to activate EuP mode.
- The system fails to retain speed settings for system fans after the fan rotation speed is set to manual.
- The system fails to enter sleep mode.
[Known Issues]
  • For x39, x59, x69, x71, x79 and x80 series NAS with Intel network controllers i217, 82574, or 82579, the maximum MTU size of these LAN ports can only be set to 8996 (you may need to set the matching MTU size on the switch/router/client as necessary).
  • [Photo Station 5] Sharing to Weibo (a Chinese social media website) using the Upload function may be occasionally unsuccessful due to the website's network stability.
  • For enhanced security on access controls, myQNAPcloud employs the OAuth 2.0 authorization protocol. If you experience difficulties accessing myQNAPcloud using mobile or client utilities, please see the following FAQs:
    1. Setting access controls to “Public” in order to use CloudLink on supported client devices: https://support.myqnapcloud.com/faq...onnected-to-my-device-using-cloudlink-service
    2. More information regarding access modes: https://support.myqnapcloud.com/faq/_faq_q_what-do-the-access-modes-for-my-device-mean
  • [TVS-871T] In certain circumstances (such as modifying the MTU size on the Mac), the Thunderbolt throughout performance may not be optimal.
Virtualization Station 2.0
( 2015/08/23 )
[Bug Fixes]
l If an SSL certificate is imported before upgrading to the latest version of Virtualization Station, then Virtualization Station cannot be launched.
l After importing an SSL certificate then enabling/disabling “Force SSL” in the Control Panel, the certificate will be changed.
l The mouse cursor is shown as a block rectangle.
[Improvements]
l When creating a remote backup or restoration task, the system will check if the remote NAS has enabled “Force Secure Connection only”.
l Added support for using Microsoft Windows 10.
[Limitations]
l This version is only available for QTS versions 4.2.0 (20150716) and later.
Cloudlink 1.1.4
( 2015/01/23 )
[Fixed Issues]
-CloudLink Agent connects to closest server base on the Geo location
-Preview previous/next files by clicking arrows on both side or pressing left/right key using keyboard
-Firmware patch number support
-Firmware patch version is displayed in tooltip in "Device Dashboard" on portal
-Firmware patch version is displayed as part of firmware version in "Device detail" page on portal
-Warning icon will be displayed on "Device Dashboard" if any new patch versions released
-Support folders' Drag & Drop into the Shared folders
-Notify users when device is unregistered
-Send email to QID user
-Send push notification to all paired mobile Apps
-Remove feature that sharing sharelink to facebook friend due to the incompatibility in Facebook API 2.1
Whoohooo! I was so happy to see the update. What a beautiful thing...QTS 4.2 ...It sure is music to our ears for those who have been waiting FOREVER. Literally eh? :D
The new interface....I like it as it's refreshing....
If Windows 10 and Apple iOS had a baby . . . QTS 4.2
Yep, they have a bit of the "modern/metro/material" UI design stuff in there - most of the apps, once launched are pretty similar to QTS4.1, so not a big jump...
They did clean up some of the apps - better job with the volume management and storage pools, as this, in the past, was a bit daunting for folks that may have never worked with that kind of functionality and how they relate to disks, raid configurations, setting up the volumes, etc...
Just to follow up after a couple of days running QTS 4.2
No issues to report - I'm not running some of the higher order features - but as a RAID10 SMB/CIFS server with Virtualization Station enabled (with a dedicated NIC, not using the new virtual network interfaces/soft-switch) it's running fine...
This is running QTS4.2 on a TS-453Pro
Looks nice - I don't spend too much time in it once things are setup, but they polished the chrome up a bit...
